New Kumho ECSTA V700
New User
Tirerack has the new Kumho ECSTA V700 competition tire up on there website (no availability or price yet). Didn't know if anyone was aware.
http://www.tirerack.com/tires/kumho/ku_ecsta_v700.jsp
Re: New Kumho ECSTA V700 (J28S)
This is discouraging. Check out the specs for this particular size. It says the tire was designed for a rim width of 7.0-8.5 inches, which is much wider than the 6.0 of the ITR's
The 225/50/15 OTOH is designed for a rim width down to 6.0 inches. Wonder why there's such a difference?
http://www.tirerack.com/tires/Spec.j...del=Ecsta+V700
225/45/15 out of stock until July 15th.
$120 each.
$120 each.
I shoot brides
Re: New Kumho ECSTA V700 (typer_801)
i've noticed that tires w/ taller sidewalls will fit onto narrower wheels. I guess the shorter sidewall doesn't like to be "squeezed" onto a narrow wheel.
yoshi - who's disappointed that 225/45 may not fit stock size wheels
Re: New Kumho ECSTA V700 (yoshi234)
Acctually I'm a little worried. The Victoracer was so excellent, and every time a manufacturer has "improved" their R-compounds lately they are much worse for slalom and better for track use.
Global Moderator
If the 225/45/15 doesn't fit then it will be interesting to see many itr autoxers hoarding the remaining 225/50/15s.
reid - who goes to call tirerack...
[Modified by Reid, 5:24 PM 6/15/2001]
Re: New Kumho ECSTA V700 (lundgren)
Yes, the current Hoosier's fit, but after about 6 runs you need a new pair of fronts Not worth the extra performance IMO when they wear out that quick.
The hoosier 225/45/15 fits on a 15x6 rim, I'm sure the new kumho will too.
I'm sure it will fit, but will it be the optimum width for the particular tire? Running 225/45/15 on a 6" width rim will make the tire loose some of the contact patch. The effective contact patch might be even smaller than if u use 205 on a 6" width rim. Not only that but to get the correct tire pressure will be impossible to. I used to run 225/50/15 Kumho V700 on a 7" width rim. And it is almost impossible to get correct tire pressure. This is verified with tyre pyrometer. Actually overcooked a pair of front tire in one of the race. now I'm running with 8" width rim and it's better.
I recommends to talk to fellow racers, prefferably more experienced one and ask of his/her experience.
New User
from the very little i know..
the other V700 have been selling in europe and asia for some time now..
2 years or so ..
go check it out at kumho's website
they do'nt have the victoracer there though..
wonder if this "new" tires will be better for most applications ..
2 years or so ..
Re: New Kumho ECSTA V700 (JinMTVT)
they are still special order only from tirerack, who doesn't actually have any yet...they told me they had an "unofficial" release date of 7/15 or so...
I ordered some a few weeks ago....
dw
dw
apexinghonda
17
01-18-2006 06:51 PM
