my tires are rubbing...
i currently have 205/55/15 tires on my car and whenever i cut the wheel really hard they rub against the inside of the wheel well. relatively soon i will be replacing them with a 50 series tire, but i dont think thats going to solve everything. what else can i do to get more space between? should i have the walls rolled like the kids that put 19's on their civics?
Re: my tires are rubbing... (manick)
Stiffer springs would help minimize the body roll. Raising the car up a little is another solution. More negative camber will tilt the top of the wheel in more. All these options have trade-offs but will work.
Re: my tires are rubbing... (Steve91)
i plan on ordering some eibach sportlines and koni yellow's to stiffen the ride. i was also thinking about a GSR/ITR front sway bar. i have the ITR front upper strut and the rear sway and they made a huge improvement, but im not sure how much impact the front sway will have. do you think that in conjunction with some lower profile tires will be enough? thanks..
JinMTVT
08-12-2001 07:14 PM
