making down?
Since the desire here seems to be to achieve all changes through aero...
Consider an annular wing, instead of the more typical wing. Reduced rear lift and reduced drag, a relatively unique look, but no real downforce production. You'd have to go 100% custom though.
Or vortex generators on the roof to reduce rear lift. Or a properly designed spoiler for the same effect. If you already have a spoiler, try adding a gurney flap. Or a full belly pan and a rear diffuser. Lots of available options here that aren't traditional wings.
I think you have a coupe correct, hard to tell by the small images?
I'm running a 2000 EX coupe with a front splitter and rear APR adjustable wing, no diffuser or underside work [yet]. I also had a loose tail end until an adjustable wing was added, problem solved. Front grip was then the issue, front splitter and air dam was installed and that problem was also solved. With all the grip I was then getting, oil starvation started to be the main issue...lol.
I'm not sure as I have never attempted underside only work to solve my loose tail end. I've not found a bolt on kit as of yet and may be the reason I never did that. Seems to be a ton of work for something that would get a bit of abuse. My front splitter from one "off" was almost destroyed and took some time to get back to working condition again, can you imagine repairing a full underside?
Hope that was remotely helpful for you...good luck with your soultion and please let us know what you did.
Sorry, large picture. Google seems to produce many more images for plane/jet use than automotive, and I don't have time to do a better search.
...a full underside maybe?
oh thats crazy lookin. never seen anyone utilize that idea
that is very helpfull thanx. i do have a 99 ex coupe. how does it look with the apr wing? i know this chassis is easy to make look weird lol. ive been looking into materials llike trailer wall lining to underpanel the front and rear sections. still alot of work when your upside down. im deff gonna work on a splitter now.all i have is a type r lip, ya huge air pocket down the middle lol
And yes, there is more car than tallent at this stage, lol. Have yet to find the edge in other words.
that looks good man. basically what im trying to do lol the wing isnt as bad as i thought but id still better get my splitter figured out. i was thinking of using that chargespeed rep lip too
NewCarScent
Feb 7, 2013 05:09 PM
Neptronix
12
Apr 20, 2010 06:07 AM
beanbag
Nov 6, 2008 04:37 PM
