Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Looking for help...
Old Oct 30, 2002 | 11:48 PM
hondacivic4g's Avatar
Default Looking for help...
Ok, i'm dealing with a 99 integra LS. I want to put together a well rounded suspension package.It will incompass,daily driving, the occassional auto-Xand some quarter mile time slips.I'm looking for springs,shocks/struts(adjustable), or coil-over set up, sway bars, tie rod bars, upper tower strut bars.I've looked at several companies, not sure which to choose.So far this is just a list I've put together , but all suggestions are welcome.
Springs- Eibach pro-kit,neuspeed race,comptech sport,skunk2
Shock/strut-Koni yellows,Tokico Luminia,KYB AGX
Coil-overs-Ground control,skunk2,comptech koni package
Sway bars-Eibach,Suspension Tech.,comptech
Strut tower bars-Eibach,Neuspeed,comptech
Tie rod bars-Eibach,neuspeed,comptech
I'va had several people suggest the Suspension Technics sway bars
My thing is that the Sus. Tech sway bars are 25mm front and think 19 mm rear
The Eibach Sway bars are 27mm front and 22mm rear.
Any help and info is much appreciated.
Thanks-HC4G
Old Oct 31, 2002 | 04:31 PM
Default Re: Looking for help... (hondacivic4g)
Ok, so twenty people have viewed this and no responses? Um, did I pick the wrong forum to ask this question?
Old Oct 31, 2002 | 04:38 PM
.RJ's Avatar
.RJ
Well what you are looking to do with the car isnt what most people in the forum do with their cars... however just be patient and i'm sure some of those with more (honda) experience will share their opinions.
RJ
Old Oct 31, 2002 | 06:18 PM
Crack Monkey's Avatar
Most of what you listed is good stuff.
Eibach pros. KYB AGX. stock front swaybar. 19-22mm rear. Make sure whichever rear sway you choose, you properly reinforce the rear subframe (where the bar mounts to the unibody) - some bars come with a kit, some do not (but you can make you too).
Edit - the ITR rear swaybar is probably an economical choice, and you might be aboe to get one used from ebay or something.
[Modified by Crack Monkey, 7:19 PM 10/31/2002]
1 point 6
May 17, 2003 08:44 AM
hondacivic4g
Oct 31, 2002 05:14 PM
96_GSR
Jun 10, 2002 03:32 PM
01gizzer
May 29, 2002 01:27 PM
