Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Gravity bleeding
Old Jul 14, 2003 | 12:09 PM
Vince_badaz's Avatar
Default Gravity bleeding
Has anyone ever heard of gravity bleeding? You're supposed to open all four bleeding nipples on the calipers and let it sit over night with some kind of buckets under the brakes. My friend told me thats the way they bleed the brakes of UPS trucks. His brother-in-law is a chief mecanic there. He tried it on his car and it worked...
Has anyone ever heard of this?
PL
Old Jul 14, 2003 | 12:10 PM
Evan55's Avatar
Default Re: Gravity bleeding (Vince_badaz)
beware: RJ is coming and much talk of l00ps and t00bs will commence
the air in the system is supposed to come out of the system.
Old Jul 14, 2003 | 12:16 PM
jc836's Avatar
Ready, set, open and bleed. That is the way some Honda techs actually do the flush and bleed-gravity is good for that if the system has not been tampered with. At least that is what i was told.
Old Jul 14, 2003 | 12:24 PM
WRXRacer111's Avatar
Default Re: Gravity bleeding (jc836)
it works... just takes an infernally long time to do it. probably wouldn't take all night, and you'd run the risk of having it run the M/C dry, undoing all your hard work, or lack thereof.
Old Jul 14, 2003 | 07:08 PM
SicNA94TegGsR's Avatar
Swollen Member
Vince, I have heard not to open more than one bleeder at a time, because otherwise air can track back into the system. It DOES work though, if you have the time, 5-10 min per corner. just keep your eye on the resevoir, so as not to run it dry.
Old Jul 14, 2003 | 09:15 PM
Default Re: Gravity bleeding (SicNA94TegGsR)
Ill try it out this week a bleeder at a time, 10 min. Ill keep you posted.
Old Jul 15, 2003 | 09:17 AM
electronspeeder's Avatar
I've heard from race mechanics that this way is a great way to bleed.
Old Jul 16, 2003 | 08:36 PM
Mr. Choi's Avatar
New User
Default Re: Gravity bleeding (electronspeeder)
i think its an ok way to flush the brake lines, but not so good if you have air in it since the air will travel upwards and gravity
wont suck the fluid fast enough to expel the air trapped inside.
theineffable
Honda Civic (2001 - 2005)
Nov 27, 2009 10:31 AM
avaldez
Jul 17, 2009 11:29 AM
mortificationrock
10
May 19, 2007 10:42 PM
budget
Apr 27, 2005 06:02 AM
JSIR
Feb 10, 2002 05:04 PM
