Eibach ERC springs.
Eibach ERS springs.
Does anyone know if thes will generally fit any coilover system? I have a set of tokiko coilovers and I would like to run the erc's in them, this gonna work?
The spring rates for the tokiko's are 180/300
SORRY I MEANT ERS Springs not ERC
[Modified by AKA EneMy X, 8:33 PM 10/11/2002]
Re: Eibach ERS springs. (AKA EneMy X)
They come in either 2.25" or 2.5" i. d. They also come in various lengths & spring rates as I'm sure you know. Both ends come designed to sit on a flat perch or mounting surface. That being said, you should be able to find something to fit.
You can also consider H & R. They come in 60mm (2.3") & 52mm (?).
be wary though...I called tokico inquiring about the max spring rates their illumina's can handle.....not very high....it was like 280-300 for the front and 150-180 in the rear....
Re: Eibach ERS springs. (carl_aka_carlos)
ooh yea thats bad, yea I called them up also. I guess ill just pick up some koni yellows and some Ground controls I suppose.
Michael Delaney
09-26-2002 06:21 PM
