Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Corner Balancing Not required?
Old Apr 3, 2003 | 07:22 AM
acura_typer's Avatar
Banned
Default Corner Balancing Not required?
So I just got off the phone with a shop here in town that sets up cars for various styles of racing. I was inquiring about corner balancing. He asked the car and if i had coil overs on it, then asked what kind of sway bar links I had. I told him non-adjustable, he said "no need to cornerbalance it then". I asked why, his reply is as follows:
"Since you always do corner balancing with the driver in the car and have to disconnect the sway bars so that there is no preload from the driver's weight, when you connect the sway bars back up, if they are adjustable you set them for 0 preload. Therefore, if you don't have ajustable sway bar end links, no need to corner balance the car"
Your thoughts?
Texas HybridGarage Forum Now open
My Dyno
[Modified by acura_typer, 10:24 AM 4/3/2003]
Old Apr 3, 2003 | 07:25 AM
RacerBowie's Avatar
Default Re: Corner Balancing Not required? (acura_typer)
I would still corner balance it.....but get some adjustable endlinks as soon as is reasonable.
Preload is bad, but not bad enough to completely cancel out proper cornerweights.
Old Apr 3, 2003 | 07:26 AM
Banned
Default Re: Corner Balancing Not required? (RacerBowie)
so if I got some scales that had a margin of error +/- 20lbs, and set it up for now, thats better than nothing, right? Who makes adjustable endlinks for the R?
My Dyno
Old Apr 3, 2003 | 07:32 AM
Flux's Avatar
I am planning on cornerweighting my R this weekend and this is the first I have heard about something like this. I knew it was important to disconnect the sway bars, but I didn't think that hooking them back-up negated anything you do.
Info from GRM: http://www.grmotorsports.com/cornerweight.html
Old Apr 3, 2003 | 07:59 AM
Crack Monkey's Avatar
He is correct, in that swaybar preload will have an effect on corner weights. Corner weighting shoudl take place with the bars disconnected, then the bars set to 0 preload when reconnected.
What type of endlinks does the R use? On my RX-7, the links are a vertical bolt, surrouded by polyurethane cylinders, running from the bar to the control arm. By changing the length of the polyurethane blocks, I can alter preload.
Old Apr 3, 2003 | 08:04 AM
Banned
Default Re: Corner Balancing Not required? (Crack Monkey)
The ITR uses two types.
The front: #6
The rear (not as clear)
Not much room for adjustment really.
Old Apr 3, 2003 | 09:17 AM
metalworker's Avatar
There are alot of things that effect corner weights, which you might not have control. Just about all the rubber bushing in the suspension, if not normalized to the ride height, can effect weights. With street suspensions you do the best you can.
In a situation were the swaybar has non-adjustable links, corner weight the car with swaybars unhooked, then hook everything back up, see what happens. Sometimes you can put spacers under the mounts and adjust things a bit. I think its always a good idea to corner balance. When a customer brings a ill handling car into my shop, getting the weights right is usually the biggest step in getting their problems solved.
Old Apr 3, 2003 | 10:09 AM
Banned
Default Re: Corner Balancing Not required? (metalworker)
does anyone know of any other shops in the Houston/Galveston Area that does this service?
stevel
Suspension & Brakes
Jan 13, 2005 10:03 AM
ChaseIntegra
19
Nov 29, 2004 12:16 PM
96 SOHC VTEC
23
Jun 20, 2002 05:30 PM
SEFIxCivic
May 13, 2002 07:17 AM
