Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Brake question
Old Dec 23, 2002 | 12:25 PM
underpressure02's Avatar
Default Brake question
I was told to ask over here that some one may be able to help me out. I have a 92 Civic Si with LS brakes on the front. Many people have told me to get brembo blanks from autozone b/c they are only like 20 bucks and have a good warranty. But every autozone I go to in PA where I live has never heard of them. Can anyone help me out? What are a good set of rotors and pads to run? I drive my car over a 1000 miles per week. TIA
Old Dec 23, 2002 | 12:30 PM
r2x's Avatar
r2x
Default Re: Brake question (underpressure (wtbimport))
Do you autocross? ...HPDE? ...or just street use? The answer will vary depending on how you answer that question.
Old Dec 23, 2002 | 12:38 PM
JeffS's Avatar
You're mixed up slightly.
Generally, people here are running 1) Brembo blanks OR 2) Autozone rotors. Which one depends on how much they want to spend, and if they believe the Brembo's are better or not.
Last I heard, http://www.nopi.com actually had the cheapest price on the Brembo rotors.
Old Dec 23, 2002 | 12:51 PM
Todd Reid's Avatar
Default Re: Brake question (JeffS)
the Autozone in my area (Elkton, MD) carries Brembo rotors. I use the Prelude VTEC front rotors, and they are from Brembo. they are stamped Brembo on the side of the rotor and the box says Brembo....
good luck.
Old Dec 23, 2002 | 01:06 PM
GSpeedR's Avatar
Default Re: Brake question (Todd Reid)
I know www.collettimotorsports.com used to run good deals on them, but they may have stopped. I would probably choose Brembo over Autozone, as both are cheap.
Note: my local Autozone does NOT carry Brembos so it varies with location.
Edit: fixed link.
[Modified by GSpeedR, 5:10 PM 12/23/2002]
Old Dec 23, 2002 | 04:00 PM
Default Re: Brake question (r2x)
I do mainly road driving back and forth to work and drag racing. I am just looking to get some good stopping power with what I have. I am not looking to go nuts on braking power. I need new rotors so people were saying that the brembo blanks were better then the cross drilled rotors and much cheaper. But like I said when I went to auto zone they did not have them. If anyone has any suggestions of what would be a good rotor and pad to use that would be great.
Old Dec 23, 2002 | 04:03 PM
GSpeedR's Avatar
See reply #3 and #5.
Edit: for a good street pad ==> Axxis Ultimates, Hawk HPS or HP+. Get the Ultimates because they are cheaper.
[Modified by GSpeedR, 8:04 PM 12/23/2002]
Old Dec 24, 2002 | 06:14 AM
Default Re: Brake question (GSpeedR)
So the chances of me finding them at Autozone is like a slim chance? It is a hit or miss.
Old Dec 24, 2002 | 07:32 PM
StreetMod's Avatar
expressautoparts.com has brembo blanks.
Old Dec 25, 2002 | 07:53 AM
Balled S2K's Avatar
$17 & change at (caugh) NOPI...
http://www.nopionline.com/index.cfm?...0Disc&vaffid=0
Old Dec 25, 2002 | 09:32 AM
96 SOHC VTEC's Avatar
Default Re: Brake question (Balled S2K)
I just used Autozone rotors for my first HPDE, and they held up fine. This was with 4 20-25 min sessions. However, my friend had a brand new set on his Type R, and he warped his within 3 laps. He might have just gotten a bad set, or they could just suck.
Old Dec 25, 2002 | 09:46 AM
manveer's Avatar
Default Re: Brake question (96 SOHC VTEC)
Did he break them in properly?
Old Dec 26, 2002 | 10:57 AM
Thanks did not know they were that cheap. Thanks again.
Old Dec 30, 2002 | 10:06 AM
One more dumb question. Are integra ls rotors the same size as the 92 Si rotors?
Old Dec 31, 2002 | 02:14 PM
nc-rsx-s's Avatar
New User
If you are just running on the street, and your current rotors are not warped, why do you need new rotors at all? You can change to a more aggressive pad compound and improve braking tremendously.
Andie at Cobalt or Matt at Carbotech could hook you up with great pads.
Old Dec 31, 2002 | 03:17 PM
Default Re: Brake question (nc-rsx-s)
My rotors are really warped and getting worse by the day. I do not know if they were ever cut before so I am going to look into that when I take them off. Do you have a web site or a number for those people. Thanks
Old Jan 1, 2003 | 11:21 PM
grippgoat's Avatar
As cheap as your rotors will cost, you might as well just buy new ones.
-Mike
Old Jan 2, 2003 | 06:49 AM
Default Re: Brake question (grippgoat)
Do you think the Brembo Blanks are just as good as the amaco's that Autozone sells?
DJP
Mar 8, 2008 05:39 PM
aries331
Dec 1, 2007 12:26 PM
tominos
Dec 29, 2002 09:21 PM
Raymund
Nov 20, 2002 11:09 PM
204gsr
Jul 19, 2002 09:30 AM
