Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Bottom Mount Adjustable seat bases 94-01 Integra
Old 03-21-2011, 07:41 AM
I said I don't want a title!
Todd00's Avatar
Default Bottom Mount Adjustable seat bases 94-01 Integra
I have some really nice Sparco Speeds (bottom mount) that I'd like to put into a 94-01 Integra. Since this will be a street/autox car, I'd like them to be on sliders.
Does anyone make a seat base/slider setup for this that won't set the seat up so high that your helmet will be on the roof, or will I be forced to go custom?
Old 03-21-2011, 12:56 PM
Ridin Dirty in Cali
dirty19's Avatar
Default Re: Bottom Mount Adjustable seat bases 94-01 Integra
Thats a tricky one... being bottom mount Sparco does make a bottom mount adapter set for 69.00 but that lifts you up rather than keeping you at stock seat height. But there is no sliders.
The speed seat isnt fia rated, but im sure you know that. Since your only doing auto x there is no need to have a rated seat.
Your best bet is to weld in a few cross bars on the oem rails/sliders and bolt the seat to it.
I have seen it done before.
You will be closer to the oem seat height itself which is what you want in the first place and still be able to adjust your seat position forward or back.
Old 03-21-2011, 02:19 PM
Todd00's Avatar
I thought the Sparco base solution sat you up as high or higher than OEM, so yeah--that's kinda why I asked. Didn't know if anyone else made a better solution or not. Sparco always made great seats but I always HATED their bases.
Attaching some cross pieces to the OEM rails was one of my 'custom' solutions, so looks like that'll be the route I take.
Old 03-21-2011, 02:27 PM
I love to drive
Ghetto Civic HX's Avatar
Take a look at the Planted seat base. I have it and it comes with a variety of mounting holes and plenty of extra material if you need to drill others. Just buy the Sparco bottom mound sliders and you should be set.
http://www.saferacer.com/planted-sea...productid=2341
Old 03-21-2011, 03:22 PM
danthemang3's Avatar
corbeau, that's where i got mine from for some old recaros they worked out nicely.
Old 03-21-2011, 08:38 PM
Ridin Dirty in Cali
dirty19's Avatar
Thats a nice one, and tons of holes!
I have something similar for my corbeau passenger seat.
But for a side mount you dont have as many options.
With the sliders you should only raise up an inch to an inch and a half from stock.
Not bad considering its a bolt in set up!
Old 03-22-2011, 12:34 PM
I love to drive
Believe it or not, none of the pre-drilled holes worked with my setup! I have a Recaro SE seat with Sparco sliders. The holes on the sliders didn't match up with the base because the mounting holes in the seat are kind of wide, but like I said, there's plenty of space to drill new ones.
Also, it sits pretty low. I'm 5'7" and the SE is an OEM style seat with a thick bottom cushion and my shoulders are just above the top of the door.
JDM_EJ8
10-31-2010 07:48 AM
RSZero1
10-13-2006 08:09 PM
magic hat #9
10-04-2005 11:30 AM
ED9man
28
08-29-2005 06:36 AM
magic hat #9
Northeast (Sales)
06-25-2005 10:25 AM
Quick Reply: Bottom Mount Adjustable seat bases 94-01 Integra
