Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Beaks subframe reinforcement vs. ASR Subframe Brace
Old 05-15-2010, 08:12 AM
  #51
JmurGSR98's Avatar
Default Re: Beaks subframe reinforcement vs. ASR Subframe Brace
Progress 22mm rear sway bar doesn't need any bracing. They only recommend tack welding the mounts, for those interested in buying a sway bar and not having to spend extra money on extra bracing parts. As long as the car came with a factory sway bar, that is.
Old 05-15-2010, 11:46 AM
  #52
kristo's Avatar
Right.
And what makes the Progress 22 different from the EK9 or ITR 22 which do need bracing?
Old 05-15-2010, 08:36 PM
  #53
92integraVTECgsr's Avatar
Well here is a picture of mine. I wanted a black ASR brace, but I found this gold brace and JDM ITR rear sway for cheap locally and couldn't refuse. And actually the gold looks good on the my black car.
I would recommend anyone looking to do this to use the ASR brace. It is a great piece of work and the quality is great too. I love this setup.
Old 05-15-2010, 10:00 PM
  #54
no one wants to hear the truth
cetcivic's Avatar
Originally Posted by dirty19
I find my attaching points bushings at the brace bind.
This causes the bar not to move freely and causes rear wheel hopping under braking
Working on a fix , probably a replacement with a ST swaybar that doesnt have a preload on it.
Amongst other things.
or try skunk2 lcas..they have 3 swaybar provisions on each control arm for preload adjustment
Old 05-16-2010, 12:41 AM
  #55
koczeka's Avatar
My car, my opinion...:
Old 05-16-2010, 06:34 AM
  #56
96 SOHC VTEC's Avatar
Originally Posted by Stinkycheezmonky
Really? I've never seen or heard of this. What car(s)?
<--- Been using Beaks on two cars over the last 3-4 years without problems.
I can attest to this. Years back I had a '96 Civic Ex Coupe with a 22mm rear sway with the Beaks kit. The sway bar used to creak and make a lot of noises so I yanked it and found the holes were getting wallowed out, even with the Beaks kit to the point it would have failed.
wacer
Suspension & Brakes
48
11-24-2009 09:56 AM
MyEG6
Suspension & Brakes
40
07-17-2007 02:02 PM
mrdeadman
08-01-2005 02:47 PM
StinkyTofu
07-17-2002 05:47 AM
unFOB4U
39
12-01-2001 04:41 AM
Quick Reply: Beaks subframe reinforcement vs. ASR Subframe Brace
