Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
AutoX sway bar changes; car pushes slightly
Old 08-08-2013, 07:44 PM
xotic_crx's Avatar
Default AutoX sway bar changes; car pushes slightly
Hey folks, just wanted some thought on a sway bar change. The car's my CRX Si I run in SMF, still a SOHC A6/Z6 mini-me with bolt-ons etc, so not a lot more power than an STS car and probably about 2050lbs in race weight before driver. The car however does have the OEM ZC LSD transmission. I think the diff, while still working, isn't working as strong as it once did and the car's starting to push a bit on power. It also won't rotate as well as it used to.
Currently it's on OTS Yellows, 550lb fronts, 600lb rears, HF front sway and ST rear set on middle setting. I'm noticing what feels like the occasional spinning of an inside tire. I'm on 225/45 15 Z214 C71's that may have 40-50 passes on them all this season and still feel plenty sticky. Running 0 toe and -2.8* camber up front and .1 toe out rear and -2.1* camber rear.
My question is, I have an event this Sunday and our lot isn't the most grippy (kinda rough asphault), and I'm thinking of making a sway bar change to try to counteract this issue.
Should I drop the FSB or go up to full stiff on the rear or both? I don't have time to make it to the alignment rack before Sunday or any other spring changes before Sunday, so that's my only option.
Old 08-08-2013, 07:54 PM
90_EX_Civic's Avatar
Default Re: AutoX sway bar changes; car pushes slightly
if you're good, and you have a big enough run group, you could try both.
first i would suggest to run full stiff on the rear. if you're still pushing, just undo the end links to the front.
if you work fast enough, and the run group you are in is decent size, you could do this in a few mins.
Old 08-08-2013, 09:05 PM
xotic_crx's Avatar
Well with a codriver and small run groups (usually 15-20 drivers) my only shot would be to do it at lunch between sessions. Only downside is my car has been slowing considerably in the afternoon sessions due to summer Louisiana heat and the motors getting pretty tired so even if it made it faster I'd likely still be slower.
Old 08-09-2013, 04:54 AM
well, if you have a co driver you could do it faster.
you can also just unbolt one side of the front bar. that would still do the same effect.
Old 08-09-2013, 06:07 AM
Gmedalion's Avatar
You can stiffen the back and just let some slack out on the front sway and try that out.
Old 08-09-2013, 07:57 AM
xotic_crx's Avatar
We usually barely have time to scrape the tires and adjust pressures lol, but you're right about just unbolting an end link.
Front's not adjustable or I would back it down some.
I've run no fsb before when I was on R888's and a 450/550lb spring setup and turn-in was a little vague and it was a touch loose overall.
Old 08-09-2013, 08:03 AM
F22Master's Avatar
Then just tighten the rear. Seems pretty simple.
Old 08-09-2013, 04:40 PM
Xian's Avatar
If it's me, I go stiffer on rear bar and keep rear rebound adjustment as an option to tweak the balance the day of the event. Additional rear bar should loosen the car and help put down power on corner exit...
Old 08-10-2013, 07:07 PM
xotic_crx's Avatar
Just went stiffer in the rear for now. Looking at the course map though I may end up dropping the bar ha. Will let you guys know how it feels after tomorrow, thanks for the input!
Old 08-12-2013, 11:11 AM
xotic_crx's Avatar
Thanks again for the input. Glad I didn't drop the front, car was quite on the loose side seeing how the course ended up being laid out. I think I'll keep it like this for a bit, worked pretty well, took top pax and raw lol.
Old 08-12-2013, 12:49 PM
Xian's Avatar
Glad to hear it worked well
Charlie Moua
19
08-28-2010 07:50 AM
televascular
Honda Civic (2006 - 2015)
08-29-2006 01:09 PM
Ecugrad
29
05-24-2005 03:53 AM
asmallsol
11
09-30-2003 05:33 PM
celica73
16
05-15-2002 02:42 PM
Quick Reply: AutoX sway bar changes; car pushes slightly
