Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
.81" wilwood dynapro caliper with .35" rotors?
Old 01-25-2011, 09:53 PM
logic factory's Avatar
Default .81" wilwood dynapro caliper with .35" rotors?
from the information i gather there is a maximum the pistons should travel within the caliper that should make this difficult; dynapro lists minimum rotor thickness at .75" and maximum at .83"? for their .81" caliper with 4x1.75" pistons. how does this translate into piston movement?
what if someone made some aluminum spacers in a similar shape of the pads that could keep the pistons in their similar acceptable range but would allow the use of .35" rotors for additional weight saving where suited.
has anyone done this? if not why may it be a bad idea?
Old 01-27-2011, 08:28 PM
lwnslw's Avatar
Default Re: .81" wilwood dynapro caliper with .35" rotors?
are u road racing or just trying to figure out how to make a rotor explode?
janz3n
19
04-17-2007 01:25 PM
CAN97SH
09-12-2006 05:49 AM
swlabhot
02-06-2004 09:31 PM
KMaxwell
12-25-2003 08:49 AM
sslude
01-08-2003 07:54 PM
Quick Reply: .81" wilwood dynapro caliper with .35" rotors?
