is this worth fixing
Old May 1, 2011 | 08:05 PM
jdmfyng's Avatar
Default is this worth fixing
just wondering if the rust on my ej1 passenger side door jamb is worth fixing if i was to take it to a body shop
Old May 2, 2011 | 10:38 AM
jasoncrashtech's Avatar
Default Re: is this worth fixing
get a used rocker from a wrecking yard. there's more rust in there that your not going to be able to see
Old May 2, 2011 | 12:41 PM
gorillafart's Avatar
its worth fixing if you do it yourself.
why does it already look like theres a thick slab of bondo from a previous repair? that may be one of the reasons for why its rusting. poor previous repair
Old May 2, 2011 | 01:32 PM
jdmfyng's Avatar
thanks for the input guys I bought the car like this so the previous owner prob did the bad bondoing
Old May 2, 2011 | 05:48 PM
Uncle_Willie's Avatar
I personally would take it to a shop. If a reputable shop does it they will guarantee it. If you do it yourself you always have the risk of it coming back and having to go through the same mess again
Old May 2, 2011 | 05:53 PM
civicsmoke's Avatar
^ alot of shops dont guarantee rust repair.
if they rest of the car is in good condition its worth fixing, but diy will save you alot of money.
Old May 9, 2011 | 04:44 PM
AChickInACivic's Avatar
Fix it if you want to, but if you take it to a shop you'll probably get charged out the ***.
Old May 9, 2011 | 06:27 PM
If youve never done bodywork/rust repair dont even attempt it, rust sucks even when your experienced. Plus if you dont get the body work right your door gap will be all messed up.
Old May 9, 2011 | 06:35 PM
lots of naysayers here. i say fix it yorself!
its a honda not a bently... so who cares! lol
Old May 9, 2011 | 06:57 PM
ken9's Avatar
Depend how long you gonna keep the car...If you don't plans on keeping for that long then just do it yourself. It just an old car, and it already have cancer. If you have welding machine and gas then you should be o.k..
Old May 10, 2011 | 06:19 PM
EGcivic_95's Avatar
the two shops i work in wont qurantee rust repair unless you spend a ton of money for all new panels and then we remove it by the spot welds and sand blast pretty much everything in the immediate area but thats a ton of money lol
Old May 12, 2011 | 09:32 AM
(. )( .)'s Avatar
i vote for doing it yourself. just pull the interior trim and wire wheel the whole sections. cut all the metal that's beyond the point of no return and replace it with sheet metal. besides where the filler is at by the hole, the rest looks like surface rust.
ray559527
Acura TSX
Jun 9, 2015 07:53 PM
TheCiv127
Paint and Body
Feb 20, 2013 08:48 PM
b16bri
Oct 27, 2010 07:35 PM
Decaf
Paint and Body
Jun 22, 2008 07:47 AM
Havokgsr
Oct 14, 2002 09:46 PM
