Tips for first time painters
Old Dec 16, 2011 | 09:43 PM
jdmchickx's Avatar
Default Tips for first time painters
Have some experience with painting have a project car and wanna see how it comes out. Ek hatch. I have the gun and compressor and all that, I just wanna know how much primer clear coat and base coat I'm going to need, and reducer hardener thinner etc. and what goes in what.
Is it hard to paint a car and have it come out good with right supplies patience and proper sanding?
Old Dec 17, 2011 | 02:28 AM
eyecandynsx's Avatar
Default Re: Tips for first time painters
Are you doing a complete color change or just the outside? Youre going to have to pick your products and read the data sheets that accompany each product to know what you need with it, or just ask the person at the paint shop. Primer I use is 4:1 primer to catalyst. Basecoat is used with different reducers based on temperature, you can reduce down to 1:1. Clearcoat will depend, some are just 4:1 with hardner, some people reduce their clear also slightly. Like I said, best advice is to pick the brain of the person at the paint shop, based on which brand youll be using.
Prep work really is the key. You can use the most expensive products out there, and the most expensive paint gun, but if your prep work sucked, your paint job is gonna look like ***. Be sure to get a good mask, clean the area very well so theres no dust.
Old Dec 17, 2011 | 05:49 AM
HellaFab's Avatar
there is a good video on youtube on prepping and painting by mcqueenpaint "how to paint your car" in your own garage in 2 weekends or something.
there are 10 videos on doing it.
Old Dec 17, 2011 | 09:34 AM
jdmchickx's Avatar
Yes changing colors.
Old Dec 17, 2011 | 10:58 AM
joeshmo's Avatar
Go to a body shop and ask to watch. It's all well and good to read about but being able to study and see how a gun is held and how to mix and set a spray pattern and overlap and how to properly block and feather is the best way to learn.
Old Dec 17, 2011 | 06:42 PM
jdmchickx's Avatar
Do certain reducers and hardeners need to be used with certain paint?
Old Dec 17, 2011 | 10:13 PM
joeshmo's Avatar
If you are asking this, you probably should not be painting a car.
Yes, each paint has a paint or line specific reducer and activator. "Universal" activators are not to be trusted, unless stated by the manufacturer (I can think of a few paint systems with a single activator and reducer that work in primer, base and clear.)
Old Dec 18, 2011 | 02:55 AM
Thats why its best to either research online with what brands you want to use, most companies have their tech sheets online, or talk to the people at the paint shop. They'll make sure you get the correct products for what youre doing.
For example https://buyat.ppg.com/refinishProduc...d-1c74b1ad308f
If you click on the "tech info" it will bring up a pdf that shows you what products its compatible with, and what reducers you need to use. I used that page, because thats normally the paint I use, but you get the idea of what to look for. If you surf around on there a little, youll see clear coats, primers, etc and you can see what is needed. Hope that helps
Old Dec 18, 2011 | 08:36 AM
burningrex's Avatar
https://honda-tech.com/forums/paint-body-84/everything-you-need-know-about-autobody-repair-1962364/
You should read this whole thread and watch a few videos on YouTube...
Then just go for it... If you have painted before (rattle can doesnt count) then you should be fine...
Start off with door jambs...
Old Dec 18, 2011 | 05:20 PM
jdmchickx's Avatar
My friend who owns a paint shop is doing all the mixing and stuff, I was just curious. But thanks for all the input
Old Dec 20, 2011 | 05:05 AM
HellaFab's Avatar
he will be mixing the base, but not to the activated stages because pot life of activated paint is ~4h.
Read the threads and take the advice.
Old Dec 21, 2011 | 06:11 PM
jdmdomo's Avatar
good luck with the project
Old Dec 21, 2011 | 11:35 PM
gorillafart's Avatar
heres a tip...
use the search button
Old Dec 22, 2011 | 06:10 AM
k-series's Avatar
Man, I keep forgetting about YouTube as a resource. Thanks for tips!
Steve
Mishako129
Jun 26, 2013 09:43 PM
jayturboef
Paint and Body
20
Apr 20, 2010 11:39 PM
IOSUA
Paint and Body
Jan 3, 2008 09:43 PM
InTeGrA_bLazEd
Paint and Body
Jun 9, 2007 03:31 PM
Project_EK
Mar 1, 2005 06:26 PM
