Tips for first time painters
Have some experience with painting have a project car and wanna see how it comes out. Ek hatch. I have the gun and compressor and all that, I just wanna know how much primer clear coat and base coat I'm going to need, and reducer hardener thinner etc. and what goes in what.
Is it hard to paint a car and have it come out good with right supplies patience and proper sanding? |
Re: Tips for first time painters
Are you doing a complete color change or just the outside? Youre going to have to pick your products and read the data sheets that accompany each product to know what you need with it, or just ask the person at the paint shop. Primer I use is 4:1 primer to catalyst. Basecoat is used with different reducers based on temperature, you can reduce down to 1:1. Clearcoat will depend, some are just 4:1 with hardner, some people reduce their clear also slightly. Like I said, best advice is to pick the brain of the person at the paint shop, based on which brand youll be using.
Prep work really is the key. You can use the most expensive products out there, and the most expensive paint gun, but if your prep work sucked, your paint job is gonna look like ass. Be sure to get a good mask, clean the area very well so theres no dust. |
there is a good video on youtube on prepping and painting by mcqueenpaint "how to paint your car" in your own garage in 2 weekends or something.
there are 10 videos on doing it. |
Yes changing colors.
Go to a body shop and ask to watch. It's all well and good to read about but being able to study and see how a gun is held and how to mix and set a spray pattern and overlap and how to properly block and feather is the best way to learn.
Do certain reducers and hardeners need to be used with certain paint?
Originally Posted by jdmchickx
(Post 46534822)
Yes, each paint has a paint or line specific reducer and activator. "Universal" activators are not to be trusted, unless stated by the manufacturer (I can think of a few paint systems with a single activator and reducer that work in primer, base and clear.) |
(Post 46534822)
For example https://buyat.ppg.com/refinishProduc...d-1c74b1ad308f If you click on the "tech info" it will bring up a pdf that shows you what products its compatible with, and what reducers you need to use. I used that page, because thats normally the paint I use, but you get the idea of what to look for. If you surf around on there a little, youll see clear coats, primers, etc and you can see what is needed. Hope that helps |
https://honda-tech.com/forums/paint-body-84/everything-you-need-know-about-autobody-repair-1962364/
You should read this whole thread and watch a few videos on YouTube... Then just go for it... If you have painted before (rattle can doesnt count) then you should be fine... Start off with door jambs... |
My friend who owns a paint shop is doing all the mixing and stuff, I was just curious. But thanks for all the input
he will be mixing the base, but not to the activated stages because pot life of activated paint is ~4h.
Read the threads and take the advice. |
good luck with the project
heres a tip...
use the search button |
Man, I keep forgetting about YouTube as a resource. Thanks for tips!
Steve |
