Re mounting windows on DC2
I get my car back from the shop in a day or two and have to put the windows back in myself, iv fitted and removed the electric windows before but never the sealed in rear quarters or rear screen.
How do i do this and what do i use?
thanks in advance
thanks in advance
You have to use an automotive urethane sealant...and if you would like to stiffen the car up a little bit you can use a high modulous urthane...it is deisgned for cars where the windows are an integral part of the body structure.
You will need to sut the urethane down on the glass and the body to provide a smooth bed to apply the new urethane on. If there are no scratches and the urethane bed is clean then you will not need to prime. Urethane sticks very well to itself.
For the quarter glasses you will want to cut the tip of the urethane into a 3/8 circle, then up the side of the tip cut a 1/2 tall by 5/16 wide v into it...V beads provide much better sealing than simple round beads would and keep the urethane from oozing into the car.
Then just set the glass vry accurately into the opening, and secure it while it dries, I would say it would be about 1- 4 horus dependant on the type of urethane you use.
AS for the hatch cut the V about 9/16 tall and 3/8 wide, it needs a bit of a bigger bead, and make sure the hatch is closed fully when you install the glass and don't open it until it is fully cured.
I qould recomend SICA urethanes...they are easy to work with, have a good body and are available at most any glass shop.
Oh and a regular wheetmetal saulking gun will not pump urethane, the viscosity to too high.
When you say 'sut' do you mean cut or is this some kind of other thing?
And i dont quite understand what you mean by:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DDEVIANT1 »</TD></TR><TR><TD CLASS="quote">cut the tip of the urethane into a 3/8 circle, then up the side of the tip cut a 1/2 tall by 5/16 wide v into it...</TD></TR></TABLE>
but thanks for the info
dantamparacer
Aug 14, 2009 09:05 AM
HCivExoo
19
Dec 15, 2008 08:33 AM
vtec_head
Jul 21, 2008 08:15 PM
MakoE2
Feb 11, 2004 08:31 AM
