Polyurithane painting problem (chiping)
Old Dec 10, 2007 | 01:59 PM
big_poppa49's Avatar
Default Polyurithane painting problem (chiping)
Ok. I bought a mugen style polyurithane front lip for my civic and the paint is starting to peel like in chips all over the place, all the way down to the poly. Its only been on there like 3 months! I haven't hit anything or even drug on anything. We first sprayed it with 3M adhesive promoter and then done base coat clear coat. BUT, we did not primer it b/c a friend of mine said there would be no need. So what are there like a special kind of paint for poly?? Or should I have used enamel instead of base coat clear coat. Please help! Thanks
Old Dec 10, 2007 | 02:23 PM
alltech_hybrid's Avatar
Default Re: Polyurithane painting problem (big_poppa49)
did you clean it with warm soap and water before paint? did you scuff it up good before?
you dont really need primer but i woulda used it anyway and I seal everything i paint too
Old Dec 10, 2007 | 02:24 PM
yeah, we sanded it down pretty good. Do you guys think enamel paint with primer would work better?
Old Dec 10, 2007 | 06:24 PM
iam7head's Avatar
Default Re: (big_poppa49)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by big_poppa49 &raquo;</TD></TR><TR><TD CLASS="quote">yeah, we sanded it down pretty good. Do you guys think enamel paint with primer would work better?</TD></TR></TABLE>
sand it down pretty good as sand it down smooth as glass pretty good or 600 grit pretty good?
what exact stuff did you use?
enamel works great on metal, not so good on plastic.
Old Dec 11, 2007 | 01:05 PM
Disease's Avatar
You need to use plastic prep. without it the mold release agents stay in the plastic and you just sand them in deaper. Even after using warm soapy water.
The plastic prep removes the mold release agents and softens the plastic a bit so that when you scuff it, it actually stops being shiny.
Old Dec 11, 2007 | 01:07 PM
Disease's Avatar
Default Re: Polyurithane painting problem (Disease)
So what you should use is warm soapy water. Plastic prep. Scuff with a grey scratch pad or 500. Adheasion promoter, sealer and bc/cc.
Also use a flex additive to stop major chipping also.
Old Dec 13, 2007 | 12:06 PM
crvpimpin's Avatar
i'd bet you chipping came from bugs or rocks and it probly because there is an elastic add. for plastic bumpers. its kinda like rubberized paint is the best way i can explane it. if you have ever done a rc car body with normal paint the same thing happens thats why there is special paint for those and the same goes for plastic bumpers/lips
Old Dec 13, 2007 | 06:16 PM
doubleshotz's Avatar
Default Re: Polyurithane painting problem (crvpimpin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crvpimpin &raquo;</TD></TR><TR><TD CLASS="quote">thats why there is special paint for those and the same goes for plastic bumpers/lips</TD></TR></TABLE>
Care to explain/recommend on this "special paint"?
Old Dec 14, 2007 | 01:38 AM
crvpimpin's Avatar
Default Re: Polyurithane painting problem (doubleshotz)
its not like a special brand or something its an additive that make the paint flexible after it dries so that if you scrape the bumper or bottom out and it it or rocks and stuff the most that would happen is a scrach or small chip.
Old Dec 14, 2007 | 07:58 AM
Newark Built's Avatar
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crvpimpin &raquo;</TD></TR><TR><TD CLASS="quote">its not like a special brand or something its an additive that make the paint flexible after it dries so that if you scrape the bumper or bottom out and it it or rocks and stuff the most that would happen is a scrach or small chip.</TD></TR></TABLE>
x2....aka Flex agent
Old Dec 15, 2007 | 01:22 AM
Fallen86's Avatar
Default Re: Polyurithane painting problem (Newark Built Kandy SiC-RX)
where can i get flex additive and will it work for rattle can paints? planning on doing a big project with my bike!
Old Dec 17, 2007 | 05:55 AM
* B A N N E D *
Default Re: Polyurithane painting problem (Fallen86)
Given you have to mix in the flex agent b4 you spray it, i dont think its gonna work with rattle can , unless you have some way of getting it into the can
Old Dec 26, 2007 | 04:00 PM
Fallen86's Avatar
i never knew that. thanks
Old Dec 30, 2007 | 07:38 PM
bracket 4 life's Avatar
its not adding the flex agent that is making it chip and stuff. Its not plastic prepping it, and washing it. the flex additive is for parts the flex alot. The problem is that the mold agent is trapped in the plastic and realesing under the paint causing the paint to peel and delam from the pieace. also the quality of paint could be to blame for some of this. i would only use a name brand paint that offers its own plastic cleaner and adehision promoter. this should fix the problem once you sand off the other material.
Good luck
Mr. EF
Paint and Body
14
Sep 23, 2008 07:28 PM
theslugbug
Paint and Body
Apr 9, 2008 07:58 PM
ziptie
Paint and Body
Jul 31, 2007 10:57 PM
ericlee303
Sep 10, 2006 08:51 PM
92ehatch
Oct 12, 2005 05:27 AM
