Before i do this...
Old Jul 30, 2007 | 11:00 PM
ziptie's Avatar
Default Before i do this...
Bought some spray paint from automotive touch up and going to paint my front lip.
It's flat black right now.
How high of grit do i wet sand up to before i paint it?
anything else i need to do before painting?
do i need to re-wet sand/buff after it dries?
Old Jul 31, 2007 | 02:22 AM
ek4shizzle's Avatar
Default Re: Before i do this... (zunt)
if its primered wet sand with 400 for solid colors. id say get some kind of adhesion promoter like Bulldog and follow instructions, its for plastic parts that flex so paint wont crack. dont need to wet sand the base. i recommend putting some clear coat on after paint. then wetsand and buff if needed
Old Jul 31, 2007 | 07:21 AM
WihaSi's Avatar
Default Re: Before i do this... (ek4shizzle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek4shizzle &raquo;</TD></TR><TR><TD CLASS="quote">if its primered wet sand with 400 for solid colors. id say get some kind of adhesion promoter like Bulldog and follow instructions, its for plastic parts that flex so paint wont crack. dont need to wet sand the base. i recommend putting some clear coat on after paint. then wetsand and buff if needed</TD></TR></TABLE>
I would have to say clear coat is a must... 320 grit is the lowest you should go when sanding, I always use a scuff pad and sanding paste when prepping plastic parts.
Old Jul 31, 2007 | 10:57 PM
blue2000em1's Avatar
400 WATER SAND
320 DRY SAND
But honestly,If you're going to just do a front lip.Just scuff it with a scoth brite pad ,and be sure to clean it after ,with soap and water before painting it.and yes clear is a must.
Mr. EF
Paint and Body
14
Sep 23, 2008 07:28 PM
theslugbug
Paint and Body
Apr 9, 2008 07:58 PM
JJ's civic
Paint and Body
May 6, 2007 06:59 PM
deeweezy
Aug 17, 2003 07:19 AM
