Paintless Dent Removal - Should I even attempt it?
Old 02-12-2008, 01:53 PM
strad's Avatar
Default Paintless Dent Removal - Should I even attempt it?
Rookie here. Just got a 93 bone stock integra and has some dings and a long (around a foot) but shallow dent. Should i try out doing the paintless dent removing thing? Looks easy to learn but then again i wouldn't want to make things worse. I mean, the car is pretty clean otherwise. If ever you guys do think i should try it out, what are the basics from the kit that i should have? Would greatly appreciate your inputs. Thanks.
Old 02-12-2008, 02:58 PM
iam7head's Avatar
Default Re: Paintless Dent Removal - Should I even attempt it? (strad)
you think it's pretty simple? the dude who worked on 3 of my cars took couple years to learn the trick.
if it's really easy what is the point dealer hiring someone outside to do PDR?
just to give you some idea: i do body work and paint and almost everything you can do to a car mechanically wise and i don't even want to try pdr.
Old 02-12-2008, 05:11 PM
GuNnErGoD's Avatar
Default Re: Paintless Dent Removal - Should I even attempt it? (iam7head)
Don't try it. You need the tools to begin with, plus the technique. Speaking from someone that works at a PDR shop, I would definitely NOT attempt it.
Old 02-12-2008, 05:45 PM
strad's Avatar
Default Re: Paintless Dent Removal - Should I even attempt it? (GuNnErGoD)
Thanks. It's just that guys at you tube make it look so easy to sell their stuff. I appreciate the comment.
Old 05-26-2008, 09:49 PM
acmoc's Avatar
What's PDR?
Old 05-26-2008, 10:27 PM
ChuckNorris's Avatar
paintless dent removal.
Old 05-26-2008, 10:43 PM
acmoc's Avatar
Default Re: (ChuckNorris)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ChuckNorris &raquo;</TD></TR><TR><TD CLASS="quote">paintless dent removal.</TD></TR></TABLE>
haha no I know what it stands for, what is the technique and why is it so hard, sounds like some secret force that shouldn't be used, like ryu and akuma what was it, the dark shonen, iono
Old 05-27-2008, 09:14 AM
gstewart27's Avatar
Its a technique where you remove dents without damaging the paint
Last time i saw it being done the guy used small rods to reach the dent from the inside and push them out - make a mess of it and you could have an outwards dent which would be even worse!
Old 05-28-2008, 03:56 PM
GuNnErGoD's Avatar
Default Re: (gstewart27)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gstewart27 &raquo;</TD></TR><TR><TD CLASS="quote">Its a technique where you remove dents without damaging the paint
Last time i saw it being done the guy used small rods to reach the dent from the inside and push them out - make a mess of it and you could have an outwards dent which would be even worse!</TD></TR></TABLE>
The PDR guys call those "high spots". They always happen but the trick is being able to create the least amount of high spots possible and then knowing how to tap them back down.
Modified by GuNnErGoD at 9:37 PM 6/14/2008
Old 06-12-2008, 10:58 PM
Rowdy's Avatar
Leave it to a professional.
11 years in the business here, don't skimp on this, just pay top dollar for the best work.
Get the most experienced/recommended tech to fix the dings/dents.
You can see my repairs here:
http://advanceddentrepairusa.c....html
sl0wDA9
Paint and Body
12-28-2009 09:40 AM
bmwpride
Paint and Body
05-31-2009 06:36 PM
Tammy_EP3
03-18-2003 09:09 PM
SC0TT
27
05-10-2002 05:35 PM
Jackal1598
04-11-2002 08:31 AM
Quick Reply: Paintless Dent Removal - Should I even attempt it?
