Help with paint removal
Old Sep 3, 2009 | 11:42 AM
m0squ1t0's Avatar
Icon2 Help with paint removal
I picked up a d series engine yesterday and it has red high temp paint overspray in areas, a small amount on the valve cover, dist. Cap etc... I was planning on getting some aircraft paint remover and removing it but thought I would ask about it first, because I know it's safe to use on the valve cover, just not sure about anywhere else...any opinions/ suggestions are appreciated..
Old Sep 3, 2009 | 02:58 PM
bakertime's Avatar
Default Re: Help with paint removal
Should be safe on anything metal (Double check the back of the container though, to be sure). I would just keep it away from rubber seals/wires, things of that nature.
Old Sep 3, 2009 | 06:43 PM
m0squ1t0's Avatar
What would you recommend to use to remove paint on other areas, such as the distributor cap?
Old Sep 3, 2009 | 06:57 PM
cody2689's Avatar
that stuff will do minor damage to plastic parts just make sure to wipe it off thoroughly
Old Sep 4, 2009 | 05:55 AM
bakertime's Avatar
Hmm...I think for the cap, you might be best off sanding it off, scuffing the whole thing, and repainting. Or even better you could get a new cap...they're not that expensive. Since it's plastic, Aircraft Stripper would most likely mess that up. For other plastic parts, you're pretty much going to have to sand/paint them or replace them unfortunately. I've seen automotive paint (urethane) reducer strip rustoleum off of things before, but I would be a little hesitant to put that on plastic and rubber.
Maybe someone else can add some insight on the plastic parts...
Old Sep 4, 2009 | 06:17 AM
m0squ1t0's Avatar
I think your probably right alot of the plastic can be replaced easily, unless someone else knows a way to remove the paint, lol. I believe that pouring this stuff on plastic will yield a result similar to pouring pure acetone on plastic, it will simply melt it.
Old Sep 4, 2009 | 04:12 PM
red ej's Avatar
aircraft will not eat through plastic ive used it on plastic pieces before and they ended up fine but like cody said just make sure you wipe it off thoroughly and keep it away from your skin.
Old Sep 4, 2009 | 07:06 PM
m0squ1t0's Avatar
Cool thanks, I'll be cleaning the paint off on either Sunday or Monday I'll post how it goes....
97accordbuildlx
Paint and Body
Apr 25, 2012 12:40 PM
mark_dc2
Aug 3, 2010 03:54 PM
realxfresh
Mar 28, 2009 11:48 PM
staticCRX
29
Apr 4, 2006 09:31 AM
Honda97
10
Nov 14, 2004 06:31 PM
