Good way to deep clean engine bay...
Old 09-02-2010, 02:04 PM
2000SICVC's Avatar
Default Good way to deep clean engine bay...
Im sure some of you out there clean your engine and engine bay regularly. Your engines look soo clean. What is a good way to do this? I want to spray it all off with water, but what should I cover up (distributor... etc). And what chemicals to use, and where to spray them.
Old 09-02-2010, 05:04 PM
Scudweiser's Avatar
Default Re: Good way to deep clean engine bay...
Its a good idea to cover up your distributor, alternator, starter, air filter (if its a cone filter) and fuse box. most people use old plastic bags but i have seen people use tin foil too. A degreaser of your choice (purple power, simple green, gunk engine brite ect.) will remove most of the crap, then a water based detailer applied when everythings dry will keep stuff like your plastic hoses and valve cover looking good.
Old 09-03-2010, 06:13 AM
2000SICVC's Avatar
what kind of water based detailer? never heard of it.
Old 09-03-2010, 08:27 AM
IMPATIENT's Avatar
like a quick detailer, meguiars or mothers etc. Its water based, real thin and watery like and will clean and shine up the engine bay parts and anything that can actually be cleaned and shined.
Old 09-03-2010, 11:24 AM
DC2.2_GSR's Avatar
for your faded engine bay paint, just get some cleaner wax and wax all of the exposed painted areas. it will bring the color back and look like you just painted the bay. what i do for some extra 'punch' on some important details is take off or at least loosen every engine bay accessory i can get to easily and clean and wax everything underneath. if it's an especially faded bay, i'll use my little battery or air powered 2.5" buffing wheel and compound and polish everything first, then just use a good wax. i once had a guy see his engine bay and say "wow man, it looks great, but i really can't afford to pay the time and materials bill for repainting my engine bay! you shouldn't have done that!" when i told him it's just cleaned and waxed he wouldn't believe it until i showed him how i did it.
if you want your bay cleaned real nicely, just take your time and do it step by step. it's really easy, just takes some time and an eye for detail.
Old 09-06-2010, 09:10 PM
low nd slowej2's Avatar
Now I have a question wouldn't I have to cover the valve sockets as well? So water won't go in?
I'm scared to try it on my own but they only charge 25 bucks to get it detaild is that a good price?
Old 09-06-2010, 09:11 PM
Old 09-08-2010, 05:08 AM
MyOwnMechanic's Avatar
Black Magic makes a 2in1 degreaser and detailer. I used it yesterday and it did a pretty good job cleaning everything with a little assistance from a handbrush. It didn't leave blacks shiny like I was expecting, but like quoted earlier, just buy that separate.
I used tin foil and covered everything that was electrical and exposed. Better safe than sorry, just pop your hood and start protectin stuff.
Old 09-08-2010, 05:12 AM
Im guessing you mean your spark plug channels. I just cover up the whole channel so that water doesn't soak this area. Obviously you "rinse" the motor off afterwards, so just steer away from areas with electrical components and don't gush tons of water on them and you'll be fine. Make sure to start your motor and let it run for adequate time afterwards.
Old 09-08-2010, 05:39 PM
mekken's Avatar
engine degreaser!!!!
Old 09-12-2010, 12:17 AM
a97b18b's Avatar
do you guys cover electrical plugs too?
Would you suggest the motor to be running or off?? I've read some ppl like it running so it can burn off the water faster.
On the back of purpal power or what ever it was, said not to be used on painted surfaces...have you guys had problems w/ that stuff?
Old 01-04-2012, 04:51 AM
kaitou's Avatar
sorry for reviving this from the dead
you don't spray on the degreaser. its done by hand right? so why would you need to cover all the important electrical engine bits?
Old 01-04-2012, 05:11 AM
kaitou's Avatar
http://www.ehow.com/video_4738926_degrease-engine.html
http://www.youtube.com/watch?v=rPXuU...eature=related
^this guys a jerk off. and doesnt really seem to know what hes talking about, is any of it valid?
is there a good diy?
Old 01-05-2012, 11:17 AM
HybridKOOP's Avatar
Steam is best. Followed by a good degreaser, wax, and a low-luster shine on hoses, etc. like others have said.
Most dealerships have used car engines steam cleaned. They come out amazing that way.
I've detailed hundreds of cars and bays. I will tell you that having the right BRUSHES is key. You really have to get into all of the nooks and crannies and loosen up that dirt. That makes the most difference at the end of the day.
Lou
Old 01-07-2012, 01:40 PM
joeshmo's Avatar
For detailing and keeping a nice shine, I find that aerospace 303 works great and lasts a long time, just don't be stupid and use it on belts or anything. Megs natural shine is another quality product that can be used to supplement the shine from 303 or on its own. Just make sure the surface is very clean.
What I usually do:
Cover alt with bag
Hose engine with low pressure
Cover entire bay with copious amounts of degreaser (simple green or purple power, depending on what I have available, full strength)
Blast entire engine bay with a hose attachment
Look for dirty areas, hose down and apply engine degreaser. Allow to sit for a while, then agitate with an appropraite sized brush (I find soft bristle nylon brushes work very well and do not leave marks. Toothbrushes work very well for tight areas but get dirty rather quickly, so stop often to clean it to prevent clogging!)
Allow engine to dry or dry with shop rags where water pools. All black surfaces/rubbers get aero303. Plastics get megs nat. Metal and paint get nufinish, applied and removed with small 3-in diameter hand buff/wax pads.
Take care to pay special attention to the small stuff, I always find gunk builds up quickly by my batteries and on my reservoir caps, between the embossed letters. Perfect place for degreaser and toothbrushes.
gator88
07-18-2006 04:59 AM
numotive
12-02-2005 12:13 PM
TheNasty0ne
08-26-2005 04:27 PM
K-Spec
01-30-2005 01:43 PM
X2BOARD
07-29-2002 01:24 PM
Quick Reply: Good way to deep clean engine bay...
