Fixing rust spot??
Old Aug 17, 2008 | 06:26 AM
Lee_eg6si's Avatar
Default Fixing rust spot??
Hi guys,
My civic hatch has a little rust spot right under the tail lights. The paint is still bubbling out. I was thinking of doing it myself. How should I appoarch this? What tools/materials should I use? Thanks in advance..
Old Aug 17, 2008 | 01:33 PM
Zerophase's Avatar
Default Re: Fixing rust spot?? (Lee_eg6si)
Do it old school and use fingernail polish.
Old Aug 24, 2008 | 06:26 AM
Lee_eg6si's Avatar
Default Re: Fixing rust spot?? (Zerophase)
Never heard of it before.. How do I begin? Does it require any sanding down?
Old Aug 24, 2008 | 09:38 AM
nstory13's Avatar
The only way to repair rust is to get rid of it. Get a grinder, grind it down to where you see no more rust, just bare metal. If the rust is really bad it's all the way through the metal so you might have to cut the piece out and weld another piece of metal on. The primer, then paint.
If you just want to prevent a small rust spot from spreading take some motor oil and put it on the spot you want to prevent from rusting.
Old Aug 31, 2008 | 05:26 AM
Lee_eg6si's Avatar
Default Re: Fixing rust spot?? (nstory13)
Thanks a lot
Old Aug 31, 2008 | 02:12 PM
Lee_eg6si's Avatar
I was asking around and no one has heard of this method before..how does oil help the rust spot from getting larger?? May you explain...thanks
andybmuzik
Paint and Body
Sep 4, 2011 11:00 PM
DOUBLExDEUCEx22
Paint and Body
May 23, 2009 04:36 PM
MelszEg6
Dec 27, 2008 09:11 AM
1badassEG
Paint and Body
Oct 17, 2007 08:04 PM
typhoon
Sep 20, 2004 09:17 AM
