Eurethane?
Old Aug 1, 2007 | 02:16 PM
Unique Artwerkz's Avatar
Default Eurethane?
Im doing body work on my crx bumper (91), I have been sanding it down the last few days with a DA, using 180 to strip. I was doing good, but, I used some filler and I think I used the wrong kind. It was fiberglass filler and I know it probably is the wrong thing to use. My question is, would it hurt it to use some 80 grit and just take it down to the bare eurethane and then just go up gradually and smooth it out? Help me!
Old Aug 1, 2007 | 04:45 PM
sc4dr's Avatar
Default Re: Eurethane? (Unique Artwerkz)
What are you trying to fill? Is it a Honda bumper, or aftermarket urethane, like a wings west. Try to stay away from using 80 grit on bumpers, it's hard to get the scratches out, without filling with 2 part bumper repair filler.
Old Aug 1, 2007 | 05:33 PM
Its an OEM crx bumper. I know ill need 80 on the spots where I filled.
Old Aug 1, 2007 | 05:50 PM
sc4dr's Avatar
Default Re: (Unique Artwerkz)
I got you, I didn't understand at first. You want to knock the fiberglass down with 80 grit. Thats probably your best bet considering how tough glass filler is to sand. After 80 grit use 120, 180, then prime. Block the primer with 180 or 220 after it cures, then prime again.
Old Aug 2, 2007 | 01:27 AM
Awesome man thanks alot, oh, one other question, what is blocking im kinda confused on this...thanks again!
Old Aug 2, 2007 | 05:09 AM
WihaSi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Unique Artwerkz &raquo;</TD></TR><TR><TD CLASS="quote">Awesome man thanks alot, oh, one other question, what is blocking im kinda confused on this...thanks again!</TD></TR></TABLE>
Blocking is just sanding down filler and or primer filler (with some form of sanding block), to level it off.
Old Aug 2, 2007 | 11:19 AM
crapanese's Avatar
Default Re: (WihaSi)
sand down your filler by hand ( with a block like said above ) this will make your life easier when your trying to get the panel straight. i personally wouldnt use the DA.
Old Aug 2, 2007 | 11:33 AM
Cool thanks this helps alot, so one other question, are there different types of primers out for this? I also have heard alot of people say to use adhesion promoter for eurethane? Is Bulldog an adhesion promoter? Let me know, going to finish sanding them painting hopefully this weekend. Thanks for the input so far!
akces
Paint and Body
Mar 28, 2008 06:39 AM
Unique Artwerkz
Paint and Body
Aug 3, 2007 12:55 PM
fsck3r
Jun 24, 2004 05:57 PM
lildrgn2.0
Jan 22, 2004 11:02 AM
MisterB
Oct 23, 2002 11:05 AM
