Need help again
Old Aug 3, 2007 | 10:07 AM
Unique Artwerkz's Avatar
Default Need help again
Ive got my oem crx bumper that im redoing....I broke down the filler and everything is level, then I sanded the whole bumper back down with some 180 grit paper, level and smooth. What do I do from here? Do I go up on the sandpaper or do I prime or what?
Old Aug 3, 2007 | 10:13 AM
WihaSi's Avatar
Default Re: Need help again (Unique Artwerkz)
If you're planning on stopping with 180 grit, you're gonna have to use filler primer and prime the whole bumper. Then you'll have to wet sand the filler primer with 600 or 800 grit, then of course paint it. You could also go back over the whole bumper with 320 grit, but it'll be hard to make sure you have all the 180 grit scratches out of it.
Old Aug 3, 2007 | 11:06 AM
Would I use the 320 on a DA? Also, what about the 600 or 800, by hand or on a DA?
Old Aug 3, 2007 | 12:07 PM
WihaSi's Avatar
Default Re: (Unique Artwerkz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Unique Artwerkz &raquo;</TD></TR><TR><TD CLASS="quote">Would I use the 320 on a DA? Also, what about the 600 or 800, by hand or on a DA? </TD></TR></TABLE>
You can use 320 on the DA, 600 or 800 would be by hand (and sanding block) wet, after you prime it with filler primer.
Old Aug 3, 2007 | 12:55 PM
Awesome thanks Wiha! Im going to get on it now !!
H.I CTR
Paint and Body
Dec 11, 2008 10:51 PM
mikeaitken
Paint and Body
Mar 8, 2008 12:21 PM
Finest
Paint and Body
May 21, 2007 01:34 PM
B18ls*RAYON
Jan 17, 2005 12:04 AM
bboyprelude
Aug 14, 2003 07:54 PM
