taking off paint
taking off paint
i was woundering what the easiest way to take off white paint that on door panles, dash board, ect. . . . . . .
or should i just paint over them ????
the reason why i'm asking is that i got the hatch from another person and i dont' like the white interior. . too much white hahaha
but yeah i want the car to become a sleeper and that white gives that away
thanks
thanks
Re: taking off paint (93 MR EJ1)
Is Aircraft Stripper too strong for plastics?
Re: taking off paint (ill phil)
i wouldnt use acetone,..i work with acetone all day and that shiet will eat some shiet up if you dont dry it up fairly quickly,..i would try sanding,..get most of the stuff off by sanding with a higher grit sand paper,..then use a lesser grit to smooth out and make it a little rough,..then use primer and then paint,... good luck
Delano5050
01-15-2007 09:24 AM
