Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
Timing Belt Question
Old 07-11-2017, 09:33 AM
firewood 97's Avatar
Default Timing Belt Question
I have an 2008 Ridgeline with 75,000 miles.
Service Manual says to change at 105,000 or 7 years. Mine is almost 10 years old. Should I change now?
Last edited by firewood 97; 07-11-2017 at 10:01 AM. Reason: add Ridgeline to the title
Old 07-12-2017, 04:40 AM
speedlever's Avatar
Default Re: Timing Belt Question
Good question. The RL uses the maintenance minder which will prompt you to change the TB at the OCI prior to reaching 105k miles. I don't believe the MM takes time in service into consideration. Prior to the implementation of the MM, the normal service interval was 105k miles or 7 years.
i also have a 2008 RL with 107k miles and am waiting for 120k miles before changing the TB/water pump, spark plugs, hydraulic tensioner, serpentine belt and tensioner, valve adjustment, and replace the radiator. I don't tow and my RL is garaged.
if you drive in severe service conditions, you probably should consider an earlier TB service.
As usual, ymmv.
Old 07-12-2017, 08:22 AM
somick's Avatar
If it was me I would change the belt now.
Even if you pay somebody (around 1000 dollars) it is still cheaper than a new engine.
If you do it yourself it may cost you only 150 dollars for parts.
Good luck,
Sam
Old 07-15-2017, 04:34 AM
Thanks guys, I think I'll change everything now. I only put about 5000 miles a year on.
It would be 5 years before I reached 105,000. Thanks again!
RPHaustinTX
01-07-2016 06:11 PM
1yesfan
03-11-2015 07:54 PM
Saintor
07-02-2004 06:47 PM
robbin
02-07-2003 09:34 AM
Razor
09-18-2002 02:08 PM
Quick Reply: Timing Belt Question
