Timing Belt Question
I have an 2008 Ridgeline with 75,000 miles.
Service Manual says to change at 105,000 or 7 years. Mine is almost 10 years old. Should I change now?
Last edited by firewood 97; 07-11-2017 at 10:01 AM. Reason: add Ridgeline to the title
Re: Timing Belt Question
Good question. The RL uses the maintenance minder which will prompt you to change the TB at the OCI prior to reaching 105k miles. I don't believe the MM takes time in service into consideration. Prior to the implementation of the MM, the normal service interval was 105k miles or 7 years.
i also have a 2008 RL with 107k miles and am waiting for 120k miles before changing the TB/water pump, spark plugs, hydraulic tensioner, serpentine belt and tensioner, valve adjustment, and replace the radiator. I don't tow and my RL is garaged.
if you drive in severe service conditions, you probably should consider an earlier TB service.
As usual, ymmv.
As usual, ymmv.
If it was me I would change the belt now.
Even if you pay somebody (around 1000 dollars) it is still cheaper than a new engine.
If you do it yourself it may cost you only 150 dollars for parts.
Good luck,
Sam
Good luck,
Sam
1yesfan
03-11-2015 07:54 PM
Saintor
07-02-2004 06:47 PM
