GE sleeved B18C block FS
Old 02-07-2011, 04:33 AM
2 0 3's Avatar
Default GE sleeved B18C block FS
Golden Eagle sleeved B18c block: SOLD
-Used, but freshly machined, fresh never run crank bearings (installed), fresh never run rod bearsings (sized, but not installed yet), needs a bore and a set of pictons to complete it.
-Block will comes with mains, girdle, windage, new oem type R oil pump, GE head studs and a new GE head gasket.
-Comes with 89mm eagle crank already sized and installed, and LS eagle rods not yet installed
-Currently 84.5mm, slight score in cyl 1 from when previous owner attempted to size rings. The ring scored the wall when it was pushed down into the bore for measurement.
I can just barely feel it with my finger nail. I would recomend going up to 85mm.
I purchased this set up a few months back with intentions of a build up. I now need to sell it due to some $$ issues and need the extra cash.
It was a running engine which spun a rod bearing. Previous owener broke it down, freshened up the block with a hone and all new bearings. Block and crank were not affected by the spun bearing. One rod saw some heat during spun bearing but did not damage the rod. That rod was line bored to assure its still good to run. During reassembly
1 cyl wall was scratched, at that time I believe the seller lost intrest.
Thats when it went up for sale, and I purchased it.
I haven't touched it since then. I removed it from the box to inspect and then set it right back in the box and its been sitting in the garage since.
I will part the eagle crank & rods from the block if someone wants to just purchase the GE block alone but everything is already sized, so it makes sense to go as a complete setup.
BLOCK SOLD
HEAD STUDS SOLD
OIL PUMP SOLD
ITEMS STILL FOR SALE:
GE 84.5MM Head Gasket
Eagle "big bolt" LS Rods
Eagle LS knife edged Crank
2 0 3 is offline
Old 02-07-2011, 05:56 PM
dcmatt's Avatar
Default Re: GE sleeved B18C block FS
Will you part the eagle rods? Pm me price shipped to 28052
dcmatt is offline
Old 02-07-2011, 07:09 PM
2 0 3's Avatar
I would prefer not to split everything up. If someone buys the block without the rod's, than sure. But i will wait and see what happens with the block first. Thanks
2 0 3 is offline
Old 02-07-2011, 07:22 PM
chucky236's Avatar
The block that you have, can it take an 86mm bore?
What price is the block?
Is it possible to see pics?
chucky236 is offline
Old 02-07-2011, 07:39 PM
2 0 3's Avatar
pics
2 0 3 is offline
Old 02-07-2011, 07:40 PM
2 0 3's Avatar
Golden Eagle sleeves will accept a 86mm bore, Yes.
2 0 3 is offline
Old 02-08-2011, 07:47 PM
qweakers's Avatar
price for the block with main caps and girdle shipped
qweakers is offline
Old 02-09-2011, 03:52 AM
2 0 3's Avatar
pm sent
2 0 3 is offline
Old 02-15-2011, 10:07 PM
Laojoeturbo's Avatar
Can i get a price for just block girdle and caps sent to 74021
Laojoeturbo is offline
Old 02-28-2011, 03:37 AM
2 0 3's Avatar
sent you a pm
2 0 3 is offline
Old 03-01-2011, 03:32 AM
2 0 3's Avatar
Block is SOLD
Items still for sale: Eagle LS "Big Bolt" rods
GE 84.5mm Head gasket
2 0 3 is offline
jdmH2Bek4
12-22-2012 01:14 PM
1fastvik
07-07-2007 02:41 PM
kawaii05
01-25-2006 07:15 AM
RenoRacing
08-15-2004 09:03 PM
Race Egr
02-03-2004 06:38 AM
Quick Reply: GE sleeved B18C block FS
