FS: Golden Eagle Sleeved 81mm Clean LS Block
This is a Golden Eagle Godzilla sleeved b18b block. It was sleeved in december of 03 and was assembled for about a month in early february. The block has less than 50 miles on it since it was sleeved! It has copper orings and still has a pefect dead on 81mm bore and hone(crosshatching still fresh). It includes the crank and mains all in tact, as well as oil pump and a 50 mile old waterpump(ls model). Also has two fittings in the back of the block for use with an external catchcan/brether box and the stock crank case vent plugged. I will include a brand new set of ACL main bearings and thrust washers(no rod bearings). Here is the motor as it sits now complete from deck surface to windage tray and oil pickup. (Head studs, and external oil line not included!!!) No down time and no core needed! Can't beat that!
Block is sold! Thanks folks!
Vouch Thread!!!
http://www.hostedimage.com/is....6.jpg
Modified by RenoRacing at 10:00 PM 8/15/2004
Vouch Thread!!!
Re: FS: Golden Eagle Sleeved 81mm Clean LS Block (RenoRacing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RenoRacing »</TD></TR><TR><TD CLASS="quote">yeah, i restamped it in my fricken garage..... jackass.</TD></TR></TABLE>
as long as you admit it...it's all good
Re: FS: Golden Eagle Sleeved 81mm Clean LS Block (h22dude)
Golden eagle charges $150 for bore and final hone to your piston specs and turn around is about 1 week! Tom at Camp1320 will give you a deal and help you out.
Re: FS: Golden Eagle Sleeved 81mm Clean LS Block (sPaRk'iT)
Block is gone! Thanks Bruce! SpaRK'iT is a good guy who went out of the way to make it happen, he's got a vouch from me!!
Jesse
Jesse
