WTB: JDM D15b VTEC (92-95) CRANK
Old 11-01-2010, 11:40 AM
FizzGiGG55123's Avatar
Default WTB: JDM D15b VTEC (92-95) CRANK
Looking for the odd ball JDM D15b crank that has both 45mm main journals (D15 size) and 45mm rod journals (D16 size).
I'd be willing to entertain purchasing a complete long block for the right price.
Shipped if necessary to 55038 (Hugo, MN).
Cheers,
FizzGiGG55123 is offline
Old 11-03-2010, 06:19 AM
Default Re: WTB: JDM D15b VTEC (92-95) CRANK
bump
Old 11-05-2010, 07:59 AM
bump
Old 11-05-2010, 10:08 AM
leftwal2's Avatar
I got a bisimoto cam to go with that set up, produce some power!
leftwal2 is offline
Old 11-05-2010, 10:22 AM
Goin turbo. D16 rods, milled vitaras. Wish I could afford a big Bisi cam.
Old 11-05-2010, 11:29 AM
wolfmanxx5150's Avatar
I have a complete JDM D15B Vtec long block minus a few parts on the dizzy. Iordered the entire engine and tranny from a place in cananda and when we installed it there was a ticking near the bottom of the block. at that point i just ordered another from Hmotorsonline and swapped it. I have the entire engine, tranny and new napa clutch. entire engine for $300 ( i paid $1090 for engine & tranny shipped to my door step). not sure how much shipping would be. we are about 500 miles apart. if you want the whole engine i might be able to meet you in janesville wisconsin area for a little extra$ thats amost half way?? save a few hundred on shipping? let me know.
wolfmanxx5150 is offline
Old 11-05-2010, 05:51 PM
leftwal2's Avatar
Stack ur loot, ill let u know my power figures, hit me up as a friend. -now am running a d16y7 block, jdm 96 d15b vtec head, fjr rods, vitara pistons 75.5 bore, hastings piston rings, thermal 3 inch full exhaust, bisimoto 1.2 turbo cam, super tech springs and super tech titanium retainers, running on p28, in the midst of getting tuned now, moroso catch can. A catch can is important! Ohh rc injectors 550 cc, walbro fp, skunk2 cam gear, garret t04 turbo, aem fuel rail and stock pressure regulator.
leftwal2 is offline
Old 11-06-2010, 09:50 AM
So basically you're running a Y8, groovy, mind the oil pump on that Y block!! Did you port it?
My build will be a tad different. I need to mill .55mm off the Vitaras to zero deck them. I may just deck the block another .45 and end up milling the Vitaras 1mm. After coating them they should be fine with the less material above the top ring. Also milling the head about 2mm. Static CR should be around 10:1. Adding a turbo it should have a nice flat torque curve, with a pretty fast spool (disco potato).
Old 11-06-2010, 11:23 AM
leftwal2's Avatar
I didn't port it, its stock. what's wring with keeping the oil pump stock? Dammnnnn man ur doing a lot of cutting lol. I didn't want to raise my compression level.
leftwal2 is offline
Old 11-06-2010, 02:24 PM
Y blocks have always suffered, and show it with oil starved and spun bearings furthest from the pump. My y8 had rod bearing failure, and when examined you can see how each rod bearing got progressively worse (1,2,3,4). #4 was cracked in half top and bottom, but luckily didn't spin in the journal.
The D16Y5/7/8 use the same oil pump, and the oil pump is finished like crap internally. To make things worse, the Y cranks have only one oil hole per journal where the z6/a6 cranks have 2.
To help remedy the problem of oil starvation you need to port the oil passages in the oil pump. The oil pump as a whole is a great piece, but poorly finished during manufacturing. There's a beautiful write-up on what the problem is HERE and how to fix it HERE.
Yes, I want high compression in my turbo build. :D We'll see if the rods can take the abuse from high compression and a good amount of boost. Looking for around 300whp, give or take 100, lol. It's all fun and a good learning experience. Maybe the pistons will melt, maybe they won't, never know until I try.
Old 11-07-2010, 03:56 AM
leftwal2's Avatar
That's scary, I just have a brand new oil pump, nothing aftermarket in the pan, just the fjr rods and vitaras are down there in the block and the bisi, and supertech at top with a touch of skunk2. Well im not out to really dog on my whip, just want to enjoy it, took me 2-3 years to build and drove her for the first time last night, without problems. Stiff suspension made it quite a ride.
leftwal2 is offline
Old 11-08-2010, 04:46 AM
Sounds like fun, just take care of your oil and filter changes and don't over rev. Maybe when you feel ambitious you could drop the oil pan, remove crank pulley and remove the oil pump. It seems like a lot of work, but it's really not so bad. I replace all my bearings with the engine still in the car, just a bit messy.
Porting it isn't very difficult.
Old 11-08-2010, 04:57 AM
Tried to send you a PM, your box is full.
Old 11-08-2010, 05:05 AM
ok, i cleared it out.
Old 11-10-2010, 08:54 AM
I have a few bites here, but....
bump!
Old 11-10-2010, 09:41 AM
leftwal2's Avatar
I wish u the best of luck. There was someone on craigs selling the block but he vanished in thin air. Otlr sold and removed it..
leftwal2 is offline
Old 11-10-2010, 09:44 AM
wolfmanxx5150 is working with me, hopefully it pans out. I won't stop looking until I have one in hand.
Old 11-14-2010, 08:02 AM
bump
Old 11-14-2010, 12:23 PM
leftwal2's Avatar
Nothing yet?
leftwal2 is offline
Old 11-15-2010, 04:34 AM
nada
Old 11-16-2010, 05:52 AM
Dev15Bizz's Avatar
I have a jdm d15 complete longblock.. shoot an offer 262 957 0195
Dev15Bizz is offline
Old 11-17-2010, 10:10 AM
PM sent
Old 11-19-2010, 08:28 AM
bump
Old 11-24-2010, 08:06 AM
bump
Old 11-27-2010, 11:15 PM
baltour's Avatar
fgcfgcfg
baltour is offline
Quick Reply: WTB: JDM D15b VTEC (92-95) CRANK
