WI: 01' GSR 4 wheel disc brake conversion
I have here a 2001 GSR 4wheel disc brake conversion. I will not part this setup.
Includes:
-both front steering knuckles w/ ARP extended wheel studs and new lower ball joints
-both front calipers w/ brackets and hoses
-both rear trailing arms
-both rear calipers w/ brackets and hoses
-both emergency brake cables
-1" master cylinder
The only things you'll need are rotors, pads, and a 40/40 proportioning valve to achieve the full affects of this brake setup. If you want, you and I can run to my work and pick up front and rear rotors and pads. I work at a parts store so your purchase will include my 20% discount. Sounds like a deal huh?!
I want $400 firm. please bump if you view. THANKS!
I'm located in Menasha, WI right next to Appleton. Shoot me a text (don't call) if you're interested (920)540-9138. Name is Brian.
Includes:
-1" master cylinder
egricepatrol
12-05-2008 06:40 AM
