WI: 01' GSR 4 wheel disc brake conversion
I have here a 2001 GSR 4wheel disc brake conversion. I will not part this setup.
Includes: -both front steering knuckles w/ ARP extended wheel studs and new lower ball joints -both front calipers w/ brackets and hoses -both rear trailing arms -both rear calipers w/ brackets and hoses -both emergency brake cables -1" master cylinder The only things you'll need are rotors, pads, and a 40/40 proportioning valve to achieve the full affects of this brake setup. If you want, you and I can run to my work and pick up front and rear rotors and pads. I work at a parts store so your purchase will include my 20% discount. Sounds like a deal huh?! I want $400 firm. please bump if you view. THANKS! I'm located in Menasha, WI right next to Appleton. Shoot me a text (don't call) if you're interested (920)540-9138. Name is Brian. http://sphotos.ak.fbcdn.net/hphotos-..._6110369_n.jpg http://sphotos.ak.fbcdn.net/hphotos-..._7983693_n.jpg http://sphotos.ak.fbcdn.net/hphotos-..._2167903_n.jpg http://sphotos.ak.fbcdn.net/hphotos-..._4403479_n.jpg |
Re: WI: 01' GSR 4 wheel disc brake conversion
ttt
