Lighting HID/Xenon kits, Retrofits and Associated Topics
right HID problem.
Old Dec 18, 2007 | 01:12 PM
imbrzyant's Avatar
Default right HID problem.
well every so often my right HID does not work... unless i have to flick it on and off a several times then it would turn on. Sometimes it doesnt even work at all... and last night I just got a fix it ticket because of that. I hear theres a 3 minute cool down you have to do everytime you turn it off? Anybody know what could be the possible problem?
Old Dec 18, 2007 | 02:36 PM
prelude1897's Avatar
Default Re: right HID problem. (imbrzyant)
sounds like your ballast might be going out on you or loose wiring. Try swapping the ballast around and see if it still does it
Old Dec 19, 2007 | 06:04 PM
imbrzyant's Avatar
Default Re: right HID problem. (prelude1897)
thanks! will check it out.
Old Dec 26, 2007 | 05:24 PM
Turbo EG4's Avatar
From: Ghost riding my grandmamas whip YEP, Los Angeles Cali
they way you mounted your little box thing too
and loose wiring
Old Dec 26, 2007 | 09:56 PM
WheaMyRyceGo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by imbrzyant &raquo;</TD></TR><TR><TD CLASS="quote">well every so often my right HID does not work... unless i have to flick it on and off a several times then it would turn on. Sometimes it doesnt even work at all... and last night I just got a fix it ticket because of that. I hear theres a 3 minute cool down you have to do everytime you turn it off? Anybody know what could be the possible problem?</TD></TR></TABLE>
i had this problem, the wiring was junk. the two pieces that clip together werent going in thoroughly so i took out clip pulled out the 2 wires and stuck the two wires into the other piece and electrical taped that ish! now 3 months later i think the ballest is going out so ill try to swap them to see if thats the case GL
seabassrsx19
Sep 26, 2008 07:00 PM
EJ6_Sedan
19
Nov 21, 2007 10:21 PM
Devine
Nov 28, 2005 02:31 PM
b18bEG
30
Dec 13, 2004 05:26 PM
SHystrdyGSRtdy
Jun 15, 2003 08:42 PM
