Acura TSX Acura TSX Sports Sedan. USDM TSX and Euro/UK/JDM Accord.
quick light swithc question
Old May 30, 2006 | 02:54 PM
6shootahorsenamedtrigga's Avatar
Default quick light swithc question
does the tsx have fog lights on the headlight switch (combination switch) or what i think the tl does but i forgot...i dont even know if the tsx comes with fogs so dont hate!!!
Old May 30, 2006 | 08:31 PM
tony4311's Avatar
Default Re: quick light swithc question (mphinesee)
yep the switch is on the stalking sticking out on the left.
Old May 30, 2006 | 09:29 PM
Default Re: quick light swithc question (tony4311)
so is the fog light button/switch built in to ALL headlight switches for tsx or only if you have fog lights as an option
and thanks for replying
Modified by mphinesee at 1:51 AM 5/31/2006
Old May 31, 2006 | 04:01 AM
Aznboi2k7's Avatar
actually the foglights are standard for the 06. They are on the headlight stick. if your looking at an 04-05 then its by the VSA switch, since the foglights were an option back then.
Old May 31, 2006 | 10:11 AM
vwong's Avatar
Default Re: (Aznboi2k7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Aznboi2k7 &raquo;</TD></TR><TR><TD CLASS="quote">actually the foglights are standard for the 06. They are on the headlight stick. if your looking at an 04-05 then its by the VSA switch, since the foglights were an option back then. </TD></TR></TABLE>
I think there are two versions for the 04-05. The ones from ebay seem to have the switch next to the VSA switch. However, if you buy the foglights from the dealer, the foglight switch is with the headlight stick (the combination switch) like the 06.
Old May 31, 2006 | 10:24 AM
digitalHorizon's Avatar
Default Re: (vwong)
I have an OEM foglight kit on my 05 and my switch is on the combo switch. I think the push button switch is actually a rear fog switch that people use to wire up knockoff/JDM fog light kits since the stalk switch is basically too hard to wire into in an aftermarket kit.
I have to run JDM fogs because the USDM fog light housings won't fit behind my front lip, but I wanted the OEM functionality... so I bought a USDM fog light kit from the dealer and JDM fog housings from the same shop I got my lip from, and used the switch and harness from the USDM kit and the JDM housings. That way, I maintain full US OEM functionality (and ensure a clean install) while still being able to use my front lip. I sold the USDM housings to someone who had cracked theirs for $120 I believe.
Old May 31, 2006 | 11:32 AM
Default Re: (digitalHorizon)
okay the 06 would be perfect for what i want, however the price is too high..its 78.81 before shipping now the 04+ TL has the same type of secondary on/off switch on the light switch that im looking for(its for the fog light or whatever second driving light thats in the headlight)..its only 36.92
thanks for all the replys
snake_eyes
36
Feb 26, 2011 08:20 PM
mikseries
Honda Civic (2006 - 2015)
12
Feb 8, 2007 06:13 AM
cutler2start
Dec 12, 2006 07:01 AM
4DRmafia
Nov 9, 2006 09:48 PM
al_r
Oct 18, 2003 07:28 AM
