Lighting HID/Xenon kits, Retrofits and Associated Topics
Need help with eg foglights
Old Jan 11, 2012 | 06:53 PM
KiDDD...'s Avatar
Default Need help with eg foglights
Sup guys,
I know there's a couple of DIY out there for installing foglights and such, but I'm having a different issue. The wiring on the foglights my car has were installed carelessly and all Mickey Mouse.
Earlier in the year I removed everything that I had aftermarket on my car, stereo, jdm power folding mirrors, foglights and jdm clock. I left the harness as if it was brand new with nothing attached to it. Well, I forgot how the fogs were connected on the inside of the car.
Take a look at the pics... I have the complete wire for the outside...and one wire leads inside the cabin through the firewall, from there it's not connected anywhere, just hanging out. Looking at the pic I provided, what else do I need inside to re-install the fogs?
Any input is appreciated. Thanks!
Old Jan 12, 2012 | 05:11 AM
Joon Joon's Avatar
Default Re: Need help with eg foglights
the wire going inside will go to the button and the there should be a wire from the button you need to hook to the fuse box..
Old Jan 12, 2012 | 11:11 AM
KiDDD...'s Avatar
gotcha I'm about to go check it out, thanks dude
Old Jan 12, 2012 | 05:10 PM
KiDDD...'s Avatar
Alright I ran into an issue. When I removed the fog light clip from the back of the button, it had a grip of wires attached to it which is completely different from other setups I have seen.
Pictured first I have the wires that connect to the foglight button and what they are connected to.
Second, I have the exterior foglight harness. Everything is labeled for the most part, can anyone tell me how the hell to wire these things correctly?
Thanks guys..
Old Jan 12, 2012 | 05:12 PM
Joon Joon's Avatar
thats weird.. should only be 1 relay.. i would just start off making a new harness..
Old Jan 12, 2012 | 10:05 PM
KiDDD...'s Avatar
I keep looking at other harnesses and theyre all different.
I keep questioning why mine is so different. I mean dont get me wrong, it used to work perfectly fine...so I just wanna re-install it.
But man, Im having sooo much trouble with such a lil thing...sucks.
Anyone else know how the wires work?
Old Jan 12, 2012 | 10:25 PM
Joon Joon's Avatar
can you tell me what wires goes where on the interior relay.. like 85 goes to where, 86 to where, 87 to where and 30 to where
Old Jan 12, 2012 | 10:40 PM
KiDDD...'s Avatar
sure thing I'll take some close up pics as well, give me two minutes.
Old Jan 12, 2012 | 11:03 PM
KiDDD...'s Avatar
Here we go, the pics are taken with the relay in the same position.
All shot in this position...
Top wire (30) Which has two wires...
One wire leads to the blue and yellow wire into the switch, the other has a clip at the end where I can connect it onto something...maybe the fuse box? Im holding both in my hand...
Next is this black wire leading onto the (86) spot
This wire leads to the switch, black and yellow wire.
Next, is the bottom of the relay, which is the (87) spot
And that leads to this wire, which connects to the outside red wire of the foglight harness, probably to power.
Last is this one, a black and blue wire. (85) spot
One wire is connected to BOTH black wires coming out of the switch...and the other wire is just hanging out doing nothing.
Old Jan 13, 2012 | 06:18 AM
Joon Joon's Avatar
can you clear up where the wires, on the button connector, goes.. from the way im looking at it, its not right but i want to make sure..
Old Jan 13, 2012 | 10:53 PM
KiDDD...'s Avatar
I appreciate you sticking with me Joon Joon...
I had also posted my problem on another website and got some nice results...Here's the link, check it out and let me know if you think it's right. By the looks of it, it makes sense.
http://www.d-series.org/forums/audio...ml#post2468784
blindsk8er1013
Feb 8, 2009 10:56 PM
209lsr_ly
Jan 16, 2008 07:14 PM
Stripped Honda
Apr 12, 2005 11:02 PM
Benjamin Tang
Aug 26, 2001 04:35 PM
