Lighting HID/Xenon kits, Retrofits and Associated Topics
Reverse Lights not working
Old Jan 16, 2012 | 04:48 PM
Si Speed's Avatar
Default Reverse Lights not working
Have a 98 Prelude.
I've confirmed that the bulbs are good. The cable is plugged into the transmission, all other connectors are good, and the fuse is good. All other lights work properly.
I've had the engine/tranny pulled since they last worked and the battery relocated to the trunk. Where exactly should I start tracing wires or something to get these bitches working again?
Old Jan 16, 2012 | 05:24 PM
Hawkze_2.3's Avatar
Default Re: Reverse Lights not working
I would test and replace the reverse light switch (if it's broken), it's rather common for it to go out on Preludes.
Old Jan 16, 2012 | 07:56 PM
Si Speed's Avatar
I read somewhere on here that besides that, certain changes with the wiring harness can **** it up. After engine work, I put in a P28 with S300 and the only other thing was a OBD2A->OBD1 conversion harness. I don't see how that'd affect it but I hate dealing with electronics... That shouldn't affect it should it? The car has always been 5 spd.
Canadian_EF
17
Jan 9, 2017 06:02 PM
prelude447
Feb 19, 2013 08:24 AM
CRX_Type_R
Nov 9, 2007 05:02 PM
ttk3
Aug 20, 2007 07:01 AM
BeeResp0nsible
Aug 29, 2002 07:24 PM
