Lighting HID/Xenon kits, Retrofits and Associated Topics
how do u keep high and low beam on ???? on 93 hatch
Old Mar 8, 2008 | 09:42 PM
rsdriver17's Avatar
Default how do u keep high and low beam on ???? on 93 hatch
anyone know any wiring tricks to keep the low and high beam on, on my 93 hatch. I have bi xenon hid and need the high beam to keep the sheild open, but i dont have power to them so i need the low beam on as well
Old Mar 9, 2008 | 04:40 PM
rsdriver17's Avatar
Default Re: how do u keep high and low beam on ???? on 93 hatch (rsdriver17)
bump
Old Mar 9, 2008 | 06:40 PM
Genuine Rolla's Avatar
I too, need this answered for when I go with FX35 projectors....how would we go about wiring them to get the high beam shutter to actuate while keeping power to the lows...
Old Mar 10, 2008 | 09:13 PM
rsdriver17's Avatar
bump, who knows?
Old Mar 10, 2008 | 10:12 PM
bpr0422's Avatar
Relays and diodes....
For those with bixenon PROJECTORS and no halogen, its two relays... not three.. just take out the relay that deals with the halogen high beam.
The first relay provides the main power to the ballasts
The second relay prevents the lights from being "flashed" on for the flash to pass
If yours is + trigger h4, then ground the bi-xenon solenoids to the chassis/h4 ground, and the + of the solenoid to the hi-beam+
if yours is - trigger h4, then hook up the bi-xenon solenoids to the h4 common +, and ground it at the hi-beam -
Old Mar 11, 2008 | 04:51 AM
rsdriver17's Avatar
Default Re: how do u keep high and low beam on ???? on 93 hatch (bpr0422)
nice.. but where do u find the relays and diodes?
Old Mar 11, 2008 | 08:07 AM
e46civic's Avatar
Use a relay set but you dont need diodes for a 5th gen civic. Pull the headlight switch, there will be a blank spot. The low beam wire is a big thick white wire, there may be a red stripe. Move that wire to the blank spot and your low will stay on with a your high.
Old Mar 11, 2008 | 10:27 AM
tetris53705's Avatar
cool but y keep ur high beems on ?
Old Mar 11, 2008 | 11:40 AM
e46civic's Avatar
Default Re: (tetris53705)
Because you want the ballast powered at all times when the headlight is on. Whether its a low beam only or a bixenon. Mine is wired so the stock wires activate a pair of relays for the ballasts (stock low beam to 1 side, chassis ground the other side, high beam solenoid is wired to stock high beam and ground). No diodes or extra relays to clutter up the bay. I actually used the relays from the A/C is got rid of in the car.
Old Mar 11, 2008 | 12:28 PM
bpr0422's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rsdriver17 &raquo;</TD></TR><TR><TD CLASS="quote">nice.. but where do u find the relays and diodes?</TD></TR></TABLE>
radio shack, parts express, del city, installer resources...
relays and diodes are just parts....
using relays and diodes, allows you to modify it without cutting/splicing into the stock wiring...
to keep it clean use an h4 male adapter.
Old Mar 20, 2008 | 05:21 PM
rsdriver17's Avatar
Default Re: how do u keep high and low beam on ???? on 93 hatch (e46civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by e46civic &raquo;</TD></TR><TR><TD CLASS="quote">Use a relay set but you dont need diodes for a 5th gen civic. Pull the headlight switch, there will be a blank spot. The low beam wire is a big thick white wire, there may be a red stripe. Move that wire to the blank spot and your low will stay on with a your high.</TD></TR></TABLE>
so if i do switch the wire, will my lows work as normal? and when i turn my highs on the lows will stay on along with the highs?
Old Mar 20, 2008 | 06:12 PM
bpr0422's Avatar
are you using a pnp kit?
if you are, just use relays....
don't mess with oem wiring if you do not have to.
Old Mar 20, 2008 | 11:57 PM
rsdriver17's Avatar
no right now all i have is the headlight and the stock harness, still a lil confused on what kinda relay to get or just on how to hook them up?
Old Mar 21, 2008 | 11:18 AM
e46civic's Avatar
so if i do switch the wire, will my lows work as normal? and when i turn my highs on the lows will stay on along with the highs?</TD></TR></TABLE>
Yes, so you shouldnt do it with the H4 bulbs. It might burn them out faster from increased heat. Youre still going to need a relay for the ballasts also.
Old Mar 21, 2008 | 01:00 PM
rsdriver17's Avatar
could someone provide a pic of a real relay and how you would go about hooking it up, i have two relays off the ac stuff
Old Mar 23, 2008 | 12:23 PM
rsdriver17's Avatar
anyone?
Old Mar 23, 2008 | 02:41 PM
bpr0422's Avatar
https://honda-tech.com/zerothread/1794938
Radyjr
Lighting
Feb 8, 2009 11:52 AM
rsdriver17
Lighting
Mar 5, 2008 11:03 AM
THE GUY
Mar 25, 2007 05:53 PM
bacardirico
Aug 3, 2006 03:53 PM
The Punisher
Aug 22, 2002 10:05 AM
