Lighting HID/Xenon kits, Retrofits and Associated Topics
HID issues
Old Feb 10, 2009 | 09:48 AM
mookie86's Avatar
Default HID issues
ok im just wondering what the most common issue is w/ a PNP HID kit
ok my project has been sitting for awhile now and i think the battery is weak
my problem is i hooked up my KNOWN working new HID's and when i turned on the headlights they both turned on but the passenger side flickered and shut down
now i shut off the lights and disconnected the drivers side bulb then let only the pass. side on and it worked fine
my lights are dim so i know the battery is weak but would that cause my problem
they are wired 100% correctly
Old Feb 10, 2009 | 11:10 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: HID issues
probably a defective ballast. Swap sides on the ballast and see if the problem follows the ballast.
Old Feb 10, 2009 | 11:30 AM
mookie86's Avatar
I did that as well so i know that everything is in proper working order and both lights worked w/ just standard halogen bulbs
Old Feb 10, 2009 | 12:19 PM
boynblue's Avatar
You can purchase a wiring harness for the PNP kit. That should eliminate the issue.
Old Feb 16, 2009 | 06:53 PM
lilo_goki's Avatar
i have the same problem and in need of help. i have the micota hid pNp in my integra w/jdm front end, when i turn on, my passenger side would come on and then die. i switch the ballast from my passenger side to my driver side and it works fine, the next day, i turn them on again and my driver side would come on and then die, so now what do you think it is? is it the ballast or should i get a wiring harness for the pNp kit?
Old Mar 26, 2009 | 03:17 PM
crazyheadrush's Avatar
Ive had the same problem, my driver side would come on then turn off, my problem was the pin inside the plug, it had gotten pushed out slightly so it made weak contact, so check them out make sure the rubber gasket isnt sticking out. Let me know what happens.
dc4teg95
Lighting
Feb 2, 2011 03:30 AM
DC2 Maggio
Honda Civic (2001 - 2005)
Feb 16, 2009 04:48 PM
DrewDown
Mar 3, 2007 06:12 AM
OreoDC4
Jul 23, 2006 03:57 PM
TypeRvtec18
Jan 21, 2003 08:19 PM
