Lighting HID/Xenon kits, Retrofits and Associated Topics
hid alignment issues
Old Apr 20, 2011 | 08:58 PM
///Nick's Avatar
Default hid alignment issues
hello, i recently just installed a xentec hi/lo beam bi-xenon 4300k hid kit on my 99 civic ex coupe. i installed everything perfectly and my headlights are aimed spot on. the problem im having is.. everytime i turn my high beams on, my drivers side light goes lower then the passenger side. its wierd. ive double checked everything (thinking that the bulb was put in up side down. everything is insalled correctly though. not sure if its suppose to be like this but its getting very annoying. any help? thanks guys
Old Apr 21, 2011 | 10:56 AM
TunerN00b's Avatar
Default Re: hid alignment issues
What type of "hi/lo" kit is it? Movable shield or separate bulb?
Do a proper bi-xenon retrofit and you won't have this issue.
Old Apr 21, 2011 | 04:44 PM
///Nick's Avatar
its the kind that slides back. i found what the problem was, the tabs that keep the bulb locked into the metal housing broke off so when the shield moved for high beams the bulb itselft was moving around.
dc4teg95
Lighting
Feb 2, 2011 03:30 AM
magicguy
May 9, 2009 08:09 AM
dad0c402
Lighting
Sep 21, 2008 02:16 PM
J.nguyen
Honda S2000
Aug 13, 2007 11:44 PM
Devine
Nov 28, 2005 02:31 PM
