K24a1 vs k24a4
Old 07-28-2021, 08:06 PM
Jkeller290's Avatar
Default K24a1 vs k24a4
I got a k24a1 and a k24a4, im doing a k swap on my car will be doing the type s oil pump and changing the head to a k20z3 head probably with the cams and everything which block would be better to do it with? Will be doing rods and pistons as well too
Old 07-28-2021, 09:22 PM
JRCivic1's Avatar
Default Re: K24a1 vs k24a4
If you are going to replace the OE rods and pistons, then either block will be just fine. The only benefit to using the K24A1 (CRV) block is that the main girdle is flat, so your A2 oil pump will NOT have to be modified to fit.
Old 07-29-2021, 08:14 PM
Jkeller290's Avatar
Ive read that the a1 block doesn't have oil squirters, would that be a problem at higher hp?
Old 07-29-2021, 09:11 PM
JRCivic1's Avatar
The K24A4 doesn't have oil squirters either. They are present to reduce piston temps for the reduction of knock.
Old 07-30-2021, 03:31 AM
Jkeller290's Avatar
Are they possible to put in?
Old 07-30-2021, 04:58 AM
Full_Tilt's Avatar
You dont want them. They bleed off oil and create lots of windage. If youre pushing the tuning hard enough to need them, you would want forged pistons anyway.
Old 07-30-2021, 03:51 PM
Jkeller290's Avatar
Ok thank u, any other tips for building a k24, ive never done one before and im trying to learn alot more about them
_SHIFT
03-16-2014 05:55 PM
Spankedrican92
10
07-06-2013 03:47 PM
ej2_sir
04-21-2006 01:19 AM
Quick Reply: K24a1 vs k24a4
