Need info in K-swap Honda FIT 2003,,,engine mount kit ,subframe.....
Old 04-07-2018, 08:42 PM
egycasper's Avatar
Default Need info in K-swap Honda FIT 2003,,,engine mount kit ,subframe.....
Need info in k-swap HONDA FIT 2003
what engine mount kit ,stock subframe will work or not ..........
Old 05-14-2018, 08:20 PM
DoWnfall's Avatar
Default Re: Need info in K-swap Honda FIT 2003,,,engine mount kit ,subframe.....
if you put the k24, you might need to get a mount that sits a bit lower....and your gauges.... none of them will work... there are a few parts list, but for the fit everything seems pretty *** to find someone who has done everything correctly and have it work.
Old 05-21-2018, 09:23 PM
Meyata's Avatar
what about for the k20z3? will the mounts work?
Old 05-22-2018, 09:26 AM
Chance EG's Avatar
OEM mounts will not work as is. Contact Hybrid Racing if you're serious about this and ready to put the cash down. Expect to spend a minimum of $5K, not counting the engine and trans.
LeonardDB
04-18-2011 08:41 AM
Con
23
12-18-2010 03:34 PM
Spoonin
01-27-2004 09:20 AM
0554
10
03-05-2003 10:29 PM
MugenHonda
11
01-15-2003 03:52 PM
Quick Reply: Need info in K-swap Honda FIT 2003,,,engine mount kit ,subframe.....
