Cam Angle stuck at negative
Old Apr 19, 2013 | 06:20 PM
type-GGSR's Avatar
Default Cam Angle stuck at negative
Long story short, I stored my car for the winter early due to a blown heater core. Fixed it during spring. Put everything back and went for a test drive. Noticed that the car bogged like crazy during vtec engagement. Did a datalog on Kpro, turns out my Cam angle is stuck on negative. Everything was working fine prior to this. Car is a DC2 with a K20Z1 swap.
Any help will be very appreciated.
Old Apr 19, 2013 | 07:50 PM
doood's Avatar
been there done that
Default Re: Cam Angle stuck at negative
is it throwing a code? check the vtc actuator and the actual cam gear
Old Apr 19, 2013 | 08:06 PM
type-GGSR's Avatar
Not throwing any codes.
Old Apr 19, 2013 | 10:16 PM
a1320addict's Avatar
Look at the CMP A (intake cam sensor) and the associated wiring, this is your non-fixed cam position pickup, which detects cam angle...VTC. Being you didn't mention opening the motor, chances are it's not the VTC gear or the pulseplate. Could be, but my bet is on wiring/sensor.
owneyboy
May 20, 2009 09:50 PM
nutball72
Aug 21, 2006 01:47 PM
Boost2NA
Apr 20, 2004 05:47 PM
TurbodCX
Dec 23, 2003 07:11 AM
Mr.Integra
Apr 10, 2003 01:39 PM
