New here
Old May 8, 2018 | 11:13 AM
Neil.94eg's Avatar
Default New here
Hello everyone,
I've been using this forum for some time with tech information and research however I guess I never made a username. A little information about myself; I work as an industrial maintenance technician & am currently building a 94 eg hatch base with an open deck h22a4 & lsd m2y4 tranny .
My hatch needs body work and some other tidying up. I traded my old r1 for it with the swap in it . the guy that did the swap didn't get a jumper harness so I have had to trace a ton of wires.
WHAT I'VE DONE SINCE I GOT THE CAR 8 MONTHS AGO
Tranny swap- somehow I cracked the rear case on my old tranny by the output shafts.. all the mounting holes snapped off so I had no way to mount the rear motor/tranny t bone. So I put in new fluid and a spec stage 5 clutch/lightweight flywheel. All new stainless braided clutch lines.
new headlights (tinted halos) I got them from a buddy for $50.
apexi catback with cheap stainless header
ac/ps deleted
new half radiator with fan on toggle (dual core)
installed gauges: coolant temp, oil temp, & an empty slot for wideband
swapped out all the old wheel bearings, brakes, and brake lines.
sitting on coilovers up front and stock struts with bwr lca
I've done tons of little things here and there but this is more of the larger jobs I've done.
HOW IT SITS RIGHT NOW
I had to take off the header so my dad could weld on a second o2 bung. That way I'll have one for my o2 & 1 for my wideband. I need to get a new ecu before I can drive it again. (Winter has barely ended in Wisconsin)
WANT TO BUY/TRADE
I have a virgin p28 ecu im trying to either get a chip kit put in it or trade for a p28 with a chip kit installed.
I need a wideband sensor kit...
I need an h22a4 oil pan...
I'd like to trade a black gsr leather front driver/passenger with rear as well for 2 cheaper racing seats. Or I'll buy them if it's a good deal and keep my leather as a spare.
looking for an intake manifold as well. Prefer skunk2 but would consider others.
Looking for ported or larger aftermarket throttle body.
Reasons i need a new oil pan. ...
Before new radiator/exhaust/tranny
pix4486
Mar 17, 2009 09:33 PM
Blacklabel182
Dec 29, 2007 01:33 PM
IntegraTypeR
Dec 1, 2006 05:38 PM
Eg_Ryan
19
Nov 28, 2005 10:48 PM
tim_adams85
Oct 29, 2004 01:03 PM
