help
Old Aug 28, 2016 | 09:02 PM
rnw16's Avatar
Default help
Hello, we have a 94 Honda Civic, we have been having quite a bit of issues with it & were hoping maybe you can help. Before we go into the issues we have already replaced the distributor & all the connected parts. The fuel pump does cut on when the ignition switch is in the on position, the check engine light comes on then goes off when the switch is turned. We have spark, the gas tank is almost full, and we are getting air. The Main Relay is clicking when the engine turns over. Sometimes the car will actually crank & run for a little while until it reaches normal temperature, if you turn the car off it will crank & run for a few seconds before it dies, if you try again to crank it, the car just turns over & will not crank. We have had the timing checked & were told that timing was not the issue, it does have a new timing belt & the head was replaced not too long ago. We are stumped at this point & could really use some help. Thank you for your time & we greatly appreciate any advice you may have for us.
mrau92me
Jun 3, 2018 10:37 AM
Wikd6gn
Nov 5, 2017 04:25 PM
LoGaN-VanG
13
Sep 27, 2011 05:27 PM
justhatched231
Sep 25, 2010 08:30 AM
joe_black
Sep 13, 2004 06:08 PM
