Honda Insight & CR-Z Hybrid Honda Insight and CR-Z Hybrid discussion forum.
Insight control arm mod for RSX knuckle
Old 11-15-2016, 03:28 PM
BongoBennie's Avatar
Default Insight control arm mod for RSX knuckle
This turned out to be a bit expensive but if you have resources it works well. I bought the following LCA ball joint inserts for the Type R DC5 LCA to USDM knuckle.
https://www.kingmotorsports.com/p-43...t-inserts.aspx
After he removed the stock ball joint we found that the insert was a bit small so he sleeved it and pressed it in, a washer now goes under the castle nut to hold it all together. The labor to do this was $250 for me but Im sure many on here can handle the job. later on we are going to fit Mugen compliance bushings but for now I'm leaving them stock.
Old 11-15-2016, 08:44 PM
Ryanthegreat1's Avatar
Default Re: Insight control arm mod for RSX knuckle
You should post this in the K swap Insight thread.
I made my ball joint adapters. The insight ball joint nut has a monster flange on it, no need for a washer to capture the sleeve. (not pictured)
Old 11-15-2016, 10:03 PM
Right on! do you sell these? moot point but its been a long search, ill check out the thread
Old 11-15-2016, 10:08 PM
link to that thread?
Old 11-16-2016, 10:32 AM
https://honda-tech.com/forums/insigh...ights-2703577/
Old 12-20-2018, 01:59 PM
b18ccivics's Avatar
What taper is on the rsx ball joint?
Old 12-22-2018, 07:09 AM
10*
unclematt
12
06-02-2016 04:31 AM
91blackEF
01-04-2009 01:31 PM
jolt-tsp
Welding / Fabrication
03-01-2006 09:07 AM
s-tech
08-06-2005 10:30 AM
integra15
11-29-2003 11:24 AM
Quick Reply: Insight control arm mod for RSX knuckle
