Insight control arm mod for RSX knuckle
1 Attachment(s)
This turned out to be a bit expensive but if you have resources it works well. I bought the following LCA ball joint inserts for the Type R DC5 LCA to USDM knuckle.
https://www.kingmotorsports.com/p-43...t-inserts.aspx After he removed the stock ball joint we found that the insert was a bit small so he sleeved it and pressed it in, a washer now goes under the castle nut to hold it all together. The labor to do this was $250 for me but Im sure many on here can handle the job. later on we are going to fit Mugen compliance bushings but for now I'm leaving them stock. |
Re: Insight control arm mod for RSX knuckle
You should post this in the K swap Insight thread.
I made my ball joint adapters. The insight ball joint nut has a monster flange on it, no need for a washer to capture the sleeve. (not pictured) https://lh3.googleusercontent.com/fx...w1779-h1334-no https://lh3.googleusercontent.com/bR...w1001-h1334-no https://lh3.googleusercontent.com/xt...w1779-h1334-no |
Right on! do you sell these? moot point but its been a long search, ill check out the thread
link to that thread?
What taper is on the rsx ball joint? |
10*
