z6 head with y7 block
Old Mar 16, 2007 | 11:19 PM
tuname420's Avatar
Default z6 head with y7 block
ive built up my z6 head and block{y7} the z6 has a z6 camshaft and stock cam gear. and the y7 block has stock crank and pulley. i line both the cam up to tdc and crank to tdc. and im throwing codes cylinder position sensor and tdc sensor. ive replaced the ecu with p06 maps cuz i have no vtec yet. but it bogs out and runs like **** and doesnt idle very wells. it feels like it has 20hp tops and around 2000rpm it wants to die. so do i need an adjustable cam gear and how much do i retard or advance it? anyone that has done this before please let me know ive been trieing to get it to run for weeks.
Old Mar 18, 2007 | 01:24 PM
tuname420's Avatar
Default Re: z6 head with y7 block (tuname420)
bump
Old Mar 19, 2007 | 10:25 AM
tuname420's Avatar
bump
Old Mar 20, 2007 | 07:26 PM
tuname420's Avatar
bump x4 anyone??? no one has done this?
Old Mar 21, 2007 | 01:31 PM
Bense's Avatar
oh man, these obd2 blocks with obd1 heads rack my brain. give me a bit and i'll figure it out
Old Mar 21, 2007 | 01:40 PM
Bense's Avatar
Default Re: (Bense)
okay I am assuming you have the following:
Z6 Head, Z6 camshaft, Z6 cam gear
Y7 Block, Y7 Crank Pulley
set your cam to TDC like this:
The z6 head/cam/dizzy is supposed to sync up with the p28/p06 maps at 16 degrees BTDC.
HOWEVER, the timing marks on the y7 (or any 96-00 D-series) pulley are at 12 degrees BTDC.
You can either bust out a protractor and make a mark 4degrees away from the timing mark on the y7 pulley (or 16 degrees away from TDC mark). Or use a dialback timing gun and dial in 16 and set IGNITION timing based off of the TDC mark on the crank pulley.
Old Mar 22, 2007 | 10:23 AM
tuname420's Avatar
Default Re: (Bense)
thanks that helped me and i think i know what i did wrong. i lined up the camshaft gear with the head. i ordered that back plastic thing a few days ago so ill line it up with that and it looks like the head and that plastic thing are probably a tooth off. which my car feels like it is a tooth off or so. thanks man. if this fixes my problem im sending u $5 paypal
Old Mar 22, 2007 | 10:50 AM
Bense's Avatar
and if you do that, i'm gonna send it to someone who helped me out
Old Mar 26, 2007 | 07:25 PM
tuname420's Avatar
Default Re: (Bense)
give me another 2 days and ill let u kno if it worked.
Old Mar 27, 2007 | 08:24 PM
tuname420's Avatar
Default Re: (tuname420)
well i just got done and the thing starts and dies like 2 seconds later. soooo idk. fuckfuck
powrachute
Dec 15, 2009 09:57 AM
wantasol
Jul 20, 2006 10:54 AM
EX-T
Sep 7, 2003 06:30 PM
