wiring help questions:
Old Sep 18, 2003 | 06:28 AM
hatchattak's Avatar
Default wiring help questions: 20 gauge versus 18 gauge
does the gauge of wire make a difference when making connections? i had to extend the primary O2 sensor in the dx wiring harness to the primary O2 on the b18b by using the clip from the b18b harness and using 18 gauge wire in between, while the harness itself uses 20 gauge. now im throwing the O2 sensor code.
Old Sep 19, 2003 | 04:38 AM
hatchattak's Avatar
Default Re: wiring help questions: 20 gauge versus 18 gauge (hatchattak)
bump
Old Sep 19, 2003 | 04:45 AM
VTECVillain's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchattak &raquo;</TD></TR><TR><TD CLASS="quote">does the gauge of wire make a difference when making connections? i had to extend the primary O2 sensor in the dx wiring harness to the primary O2 on the b18b by using the clip from the b18b harness and using 18 gauge wire in between, while the harness itself uses 20 gauge. now im throwing the O2 sensor code.</TD></TR></TABLE>
You are using a slightly thicker wire which shouldn't cause any problems. If you are throwing the code, double check your wiring and connections first. Shielded wire is used in the stock harness for the WHT wire on the O2 which can sometimes cause it to throw the code since it's more vulnerable to electrical interference's.
Old Sep 19, 2003 | 04:49 AM
hatchattak's Avatar
Default Re: wiring help questions: 20 gauge versus 18 gauge (VTECVillain)
thank you.
killerb7888
10
Oct 29, 2013 07:47 AM
candyman206
Dec 26, 2008 07:00 AM
1SlowSi
Feb 14, 2005 05:14 AM
Zerob16eg
Feb 9, 2004 07:47 AM
B18VX
Nov 26, 2002 07:14 AM
