will not rev past 3k b16 swap
Old 04-01-2003, 06:11 PM
dropd4door's Avatar
Default will not rev past 3k b16 swap
i just finished putting a first gen b16 into my 89 crx dx... did all the mpfi stuff.. now she will not rev past 3k... it back fires really loud too at 3 grand... anyone got any ideas...
please thanks
Old 04-01-2003, 06:56 PM
VTECVillain's Avatar
Default Re: will not rev past 3k b16 swap (jdm_crx_vtec)
The ECU is running in limp mode so you are no doubt throwing a few codes. Cherck the codes, then troubleshoot them.
Old 04-02-2003, 05:54 AM
dutchman5's Avatar
check ur timimg make sure they are correct .... if u dont know how to check the timing..there s another way to check it out .,.. start the engine and reving to 3k rpm then turn the engine off without let the rpm going down then pull out the spark plug and see what the color it is... if it s blackish then u have the wrong timing
better to fixing it before it ruin ur beautiful motor~! ! ! ! this just remind me like my mimi-me i try to fix it eveything but havent check the timing..
good luck
Old 04-05-2003, 03:27 AM
Vic Nyce's Avatar
Default Re: will not rev past 3k b16 swap (dutchman5)
i had the same problem with a P28 and a C1 swap. it would fuel cut at 3500. turns out to be a messed up ECU. swapped with a known good ECU and problem solved.
Freek
01-06-2013 02:31 PM
b16nonoy
02-19-2007 12:59 AM
wdbdycrx
03-16-2005 06:41 PM
K20EG
09-29-2003 02:09 PM
dropd4door
10
04-02-2003 07:30 AM
Quick Reply: will not rev past 3k b16 swap
