why does my h22a hatch hesitate from 1500 to 2500 rpms
Old 05-09-2003, 09:06 PM
EGh22aEG's Avatar
Default why does my h22a hatch hesitate from 1500 to 2500 rpms
Old 05-09-2003, 09:22 PM
fastwanabe's Avatar
Default Re: why does my h22a hatch hesitate from 1500 to 2500 rpms (EGh22aEG)
sorry but we need details.
what year car
is the motor stock?
what aftermarket part?
are there any codes?
does this happen @ WOT or partial throttle?
what ECU?
Old 05-09-2003, 10:19 PM
Jonathan_ED3's Avatar
Default Re: why does my h22a hatch hesitate from 1500 to 2500 rpms (fastwanabe)
my car hesitates under partial throttle from about 2k-3k.
It's really annoying, and quite hard to pinpoint the problem.
Old 05-10-2003, 08:04 AM
EGh22aEG's Avatar
the car is a 1995 cx hatchback the engine is obd1 95 with built head type s cams act 4 puck clutch i/h/e and p13 ecu it is on medium throttle between those rpms need to fix it havent been driving my car for 2 months now
Old 05-10-2003, 01:06 PM
EGh22aEG's Avatar
anyone?
Old 05-10-2003, 03:18 PM
JdmCIVIC853's Avatar
Mine does this too...but im throwing a couple of codes...hopefully when i fixed that it will go away
Old 05-10-2003, 05:17 PM
KTeller8's Avatar
Default Re: why does my h22a hatch hesitate from 1500 to 2500 rpms (JdmCIVIC853)
what do you mean by hesitate.. like studder? bog? just dont go anywhere
my h22 was like studderring up till 3k then it hit.. like i was on Nitrous or it was spooling lol... i had no go till 3 k then BOOM ... learned that the vibration was causing my wire plugs to come out of the Dizzy. had to push them back in.. no problems since
Old 05-10-2003, 06:21 PM
EGh22aEG's Avatar
Default Re: why does my h22a hatch hesitate from 1500 to 2500 rpms (KTeller8)
yea like you were saying it stutters then takes off......not the plug wires
Old 05-10-2003, 07:33 PM
Jason kiDD's Avatar
Sigh all you people are just dropping in engines and not doing research. If you still have your stock fuel pump then your car is going to buck. Ludes like a static fuel pressure to be at like 38psi and you stock pump will never flow anywhere near there. Upgrade the pump and that will take car of your part throttle bucking..
Now you owe me 5 bucks.
Old 05-10-2003, 07:35 PM
UpstateCivic's Avatar
Default Re: why does my h22a hatch hesitate from 1500 to 2500 rpms (Jason kiDD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jason kiDD &raquo;</TD></TR><TR><TD CLASS="quote">Sigh all you people are just dropping in engines and not doing research.
Now you owe me 5 bucks.</TD></TR></TABLE>
Lol, if he owes you 5 for that answer, I must owe you a whole lot!!
Old 05-10-2003, 09:20 PM
EGh22aEG's Avatar
Default Re: why does my h22a hatch hesitate from 1500 to 2500 rpms (UpstateCivic)
i already have an upgraded fuel pump
Old 05-10-2003, 10:44 PM
New User
gsrvx's Avatar
my car used to hesitate at 1500-2000...changed the spark plugs....went away.
Old 05-10-2003, 10:57 PM
5thgenH22coupe's Avatar
Thats what i was going to suggest*sp...
Bigger fuel pump did it for me.
Old 05-11-2003, 10:14 AM
SilverEk3dr's Avatar
Default Re: why does my h22a hatch hesitate from 1500 to 2500 rpms (5thgenH22coupe)
Mine did the same thing till I switched to obd1 and got hondata...(h22/ek)
Mark
Old 05-12-2003, 09:10 AM
Esoterikos's Avatar
i put bosch platinum plugs in my car and got the same problem...replaced them with ngk plugs and it went away...
Old 05-12-2003, 10:36 AM
RTFM
v4lu3s's Avatar
i havent had any problems like that though i jsut swapped out the dx fuel pump for a walbro high pressure pump.
the original pump did 23 psi at idle and 38 psi at high rpm, now it sits at 30 psi at idle and 45 psi at high rpm.
Old 05-12-2003, 10:43 AM
Jason kiDD's Avatar
Default Re: (v4lu3s)
Wow that is still low. I am 38psi @ idle..
Old 05-12-2003, 04:28 PM
Lysawy's Avatar
Default Re: (Jason kiDD)
my pump flows 40psi @ idle
my stock was at 34psi so there is a difference but i can't drive it yet so still waiting to check on that...
Old 05-12-2003, 05:08 PM
poison's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jason kiDD &raquo;</TD></TR><TR><TD CLASS="quote">Wow that is still low. I am 38psi @ idle..</TD></TR></TABLE>
Whoa, I'm at 42 I believe at idle. Maybe I'm a little too high on it
Old 05-12-2003, 06:28 PM
fastwanabe's Avatar
I am also @ 38psi at Idle and 49psi with vacuum lin off. I think it runs good no stuttering or nothing.
Old 05-12-2003, 06:32 PM
Jason kiDD's Avatar
Default Re: (fastwanabe)
Like I said 40 to 42psi should be about stock.. So you ar fine. But you can bump it all the way down the 36psi and the car will pull like a monster.. I just never kept it there because I have nothing to monitor A/F yet..
Old 05-12-2003, 07:12 PM
EGh22aEG's Avatar
i figured it out my injectors were bad it runs fine now thanks guys
702accord
08-10-2009 03:45 PM
To0sLoW
04-22-2006 06:35 PM
Terrible One
02-16-2006 09:03 PM
Quick Reply: why does my h22a hatch hesitate from 1500 to 2500 rpms
